Home > In Car Electronics (L322) > Intermittent tv reception |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35332 |
could be down to location...if the houses around you need an aerial to receive freeview then you have no hope in getting it in the FF..drive to a strong signal area and try there.. ... - .- -.
18th Aug 2015 12:11pm |
Mcnallykev Member Since: 19 Jul 2015 Location: Lanark Posts: 172 |
Thanks Stan, It isn't that. If I turn the engine off and lock the doors where it had a signal before the channel number is just
18th Aug 2015 7:24pm |
engine off and lock the doors with you inside?
18th Aug 2015 7:34pm |
No I lock from the outside and open again. I just don't get it. I have checked the connections I can see but nothing seems to be loose.
18th Aug 2015 7:40pm |
dunno.....i can only think that you are not leaving enough time for the ecu's to power back up.. ... - .- -.
18th Aug 2015 7:48pm |
I don't think so. I can leave it over night and it either works or it doesn't?? |
18th Aug 2015 8:17pm |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6729 |
Are you in the Clyde valley when you're checking this? I would be surprised if you got any signal at all to be honest. Got - 2017 SDV8 Autobiography in Loire Blue
18th Aug 2015 9:45pm |
I am at the top of it and the signal is a bit iffy but still I think the fact there is no channel number is the thing. It doesn't matter where I drive to if it has decided not to work it won't work anywhere.
19th Aug 2015 5:39am |
you could check the left rear cubby for loose cinnections and maybe water ingress.. ... - .- -.
19th Aug 2015 7:24am |
I have had a fiddle but I;m not sure which one the TV tuner is. Will keep digging around. |
19th Aug 2015 1:37pm |
Hi all, Hope you had a good weekend. This TV thing is still happening. I am making a few assumptions in that it can't be a damaged fibre optic as it wouldn't work at all. So it must be a loose cable. Can someone confirm which unit in the left hand of the boot is the TV tuner and any other leads I should check?
24th Aug 2015 8:51am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16294 |
Your box will look like this sir
24th Aug 2015 11:54pm |
Thanks Craig. That's cheap isn't it! |
25th Aug 2015 6:38am |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 |
If you have a warranty, why not ask the garage to take care of it? Ian |
25th Aug 2015 6:52am |
