Home > Maintenance & Mods (L322) > angel eye fogs/drls
Page 4 of 7 <1234567>
unless you have a halogen in one fog and one of these cobs in the other it would be difficult to judge that one pieter...when i have time i'll disconnect my drls and switch the cobs on separately and see..
@david, thanks for that info.. Wink ... - .- -.
Post #339903 30th Jul 2015 12:56pm
horse86
United States 2014 Range Rover Autobiography 5.0 SC V8 Causeway Grey
nicedayforit wrote:
@ horse 86
New separate 5pin relay required located in engine bay connected to drl's as follows:-...
very nice write-up. I was hoping I wouldn't have to splice....but figured it was probably required. :/
Hmm with the electronic gremlins these are known for I don't know if I want to stir the pot. 2014 FF Autobiography 5.0 SC
2008 FFRR (sold)
2008 BMW M5
Post #339920 30th Jul 2015 3:47pm
I don't think you need to worry. Splicing into the headlight cable, which ever you chose, only means you are adding a very small inductance circuit ( relay coil ) in parallel with a very high inductance circuit ( headlight ) which in practical terms means next to nothing. I can't see why it should upset anything, certainly didn't on mine and no-one else who has done it has reported a problem.
Post #339923 30th Jul 2015 4:05pm
as david says..i did on my td6 and my SC.. ... - .- -.
Post #339925 30th Jul 2015 4:07pm
dingg1
This thread has spurred me into ordering the bits to convert my headlights by adding 2 led halos as DRL's , and change my side light bulbs to LED's .
I had a go last night at splitting a spare headlight I have and it went well , just got to wait for the bits coming from China.
ordered 2 120mm halo rings, 2 130mm halo rings , pair of sidelight leds (13 leds in each)
and a DRL gizmo relay/loom that allows dimming lights etc
just got to see how much of it actually works on arrival Laughing Laughing
Post #339927 30th Jul 2015 4:13pm
this will be interesting , splitting the headlight seems to be the biggest problem... looking forward to the end results.. Thumbs Up ... - .- -.
Post #339928 30th Jul 2015 4:17pm
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Hi,
I just tried installing these foglights. After a little wobbling I managed to install the new LED fogs in the old Fog light frame. I found the rubbers of the old fog lights made a tight fit, instead of the isolation tape Stan used. (will post photo's later).
I now face the following problem(s).
Both the center LED light and the Angel eye flicker (engine on and off)....
Even when I turn of the lights the center LED light and the angel eye flashes once every 20 seconds or so...
Did you also had this problem Stan? How did you fix it? Probably something to do with a resistor? Who can help me?? 2002 L322 V8
Post #341484 9th Aug 2015 5:54pm
the flickering could be down to the hot & cold bulb monitoring that the FF has...i've switched mine off with my iidtool..
didnt think of using the old rubbers, good idea there Thumbs Up ... - .- -.
Post #341488 9th Aug 2015 6:20pm
pietertje
Hmm.. Could be the case indeed...
Since I don't have an iidtool... Any other solutions? 2002 L322 V8
Post #341539 9th Aug 2015 9:24pm
i have my halos are connected to a drl switch which isnt part of the FF's wiring loom so no flickering..how is yours connected up Pieter... ... - .- -.
Post #341546 9th Aug 2015 9:54pm
Stan, unless you turn off the H & C monitoring they will always have issues, even through a DRL relay Bow down Thumbs Up
Post #341554 9th Aug 2015 10:27pm
pietertje
Stan, for testing purposes I wired them into the old fog light connector.
On the right hand the center fog and on the left hand the angel eye. Both flicker when the foglights are switched on.
So Craig, are you saying that I will continue to have issues even if I use a resistor?
Sorry if I ask stupid questions but I'm an electro-newbie. 2002 L322 V8
Post #341577 9th Aug 2015 11:28pm
Pieter, without the car in front of me i couldn’t tell you 100% but yes i would expect you will still have issues even using resistors sir... Thumbs Up
Post #341579 9th Aug 2015 11:48pm
pietertje
Ok... Any way of turning H&C monitoring off without having an IIDtool? 2002 L322 V8
Post #341583 10th Aug 2015 7:24am
Would it not be possible to feed the offending flickering lights through relays using the existing fog light wiring to switch the relays and feeding the LEDs by way of a separate fused circuit direct from the battery?
You wouldn' need a IID tool then.
Post #341588 10th Aug 2015 8:07am
