Home > Maintenance & Mods (L322) > angel eye fogs/drls
Page 5 of 7 <1234567>
pietertje
Netherlands 2002 Range Rover Vogue 4.4 V8 Java Black
Sounds logical David.
But I want to use the led/halos as you described in an earlier post. So Halos as DRL's and to go off when the low beams are on.
The center led I want to use as replacement for the fog light. That would mean deviating from your earlier post right? 2002 L322 V8
Post #341592 10th Aug 2015 8:29am
it does sound like hot and cold monitoring causing the flickering Pieter...you wouldnt go wrong in investing in an iidtool tbh.. ... - .- -.
Post #341594 10th Aug 2015 8:35am
@ pietertje
The drl halo's would be wired as my previous post independently from the projector lights.
Each projector light would be wired as follows using a 4 pin relay.
Terminals 85 and 86 of the relay would be connected to the existing foglight connector.
Doesn't matter which way round.
You may or may not need a resistor in one of the wires depending on whether a "bulb out" message is displayed.
Terminal 30 of the relay would be connected to the battery or any other permanently live +12V supply under the bonnet through a fuse.
Terminal 87 of the relay would be connected to the +ve connection of the projector light.
The other terminal of the projector light would be connected to earth.
I can't see why this shouldn't resolve the flickering problem caused by feedback from the bulb monitoring system as it totally isolates the monitoring circuit from you new lights.
It is my opinion that most things added to these cars should be fed through relays to avoid such problems.
Before purchasing the required relays you could borrow a relay from the rear fuse board and wire up one of the projector lights on a temporary basis to check things work as intended. Thumbs Up
As stan says a IID tool is a good idea but I've managed to-date without one.
Post #341596 10th Aug 2015 9:00am
pietertje
Shocked Thanks again David.... Kind of answer I was looking for Thumbs Up
I know an IID tool is a good idea but I was just hoping to save the cost of it for now as I have other things higher on my priority list...
"Terminal 30 of the relay would be connected to the battery or any other permanently live +12V supply under the bonnet through a fuse."
What kind of fuse would recommend for this?
Will try to install new setup this afternoon..
Thanks! Bow down 2002 L322 V8
Post #341600 10th Aug 2015 9:50am
Something like this,
http://www.amazon.co.uk/All-Trade-Direct-S...line+fuses
You could just try the set up without a fuse in the meantime, nothing untoward will happen. Thumbs Up
Post #341601 10th Aug 2015 9:55am
pietertje
Already bought one of these (from your earlier post) will buy another...
Actually ment the Amperes. will 5 amp do?
Tx! 2002 L322 V8
Post #341604 10th Aug 2015 10:27am
5A should be ok, led's are normally only only 3-4W usually. Thumbs Up
Post #341605 10th Aug 2015 10:36am
pietertje
David,
Can you suggest an ignation switched cable in the E-box or engine bay?
I have trouble finding one....
Tx! 2002 L322 V8
Post #341704 10th Aug 2015 6:43pm
If you have Hid headlights as opposed to tungsten halogen there is an ignition switched wire to each headlight. I used one for my Drl's. Can't remember the colour of the wire but I can have a look in the morning in daylight for you. Thumbs Up
I've never really poked about in the E box, too many screws to undo on the lid to get access. Smile
I don't doubt there is an ignition source in there, will have to have a look.
Post #341726 10th Aug 2015 9:14pm
http://www.fullfatrr.com/forum/post117872.html#117872 ... - .- -.
Post #341730 10th Aug 2015 9:33pm
pietertje
Thanks both!
Unfortunately I have the halogen headlights (both dim and main).... So not sure if that uses the same set of cables as your HIDs..
Also some photo's of my set-up... Almost the same as Stan's except for the old rubber I used, which made a very nice and tight fit.
I also made three new holes for screws so I could adjust the lamp any way I want to..
 2002 L322 V8
Post #341734 10th Aug 2015 10:13pm
i like the idea of the light adjustment, nice one Pieter...
re the ignition feed, put a multimeter on the headlight plug .. Thumbs Up ... - .- -.
Post #341768 11th Aug 2015 8:18am
Unfortunately tungsten headlights don't have an ignition feed.
The good news however is there is an ignition feed in the E box which is readily accessible.
If you take the lid off the box, in the front left corner of the box facing the car there is a blue relay in the corner with a 5 way beige fusebox next to it.
The fuse box is supplied with an ignition feed from the blue relay which means that all the outputs from the fusebox are ignition controlled.
If you put your finger under the fuseboard you can lift it up clear of the E box. because of the cables the blue relay will also lift up.
On the underside of the fuseboard is a Red/Blue wire, this is the most convenient cable to splice into.
There you have it. Thumbs Up
All as per the photos below.
Post #341804 11th Aug 2015 11:24am
proser
Thumbs Up Thumbs Up Regards
Mark
2012 Westminster
GONE - 2007 Java Black FF Vogue, with Ivory interior
Post #341806 11th Aug 2015 11:29am
pietertje
Tx -again- David! Bow down Bow down Bow down
Job done with your clear instructions!
Now have the DLRs switched on ignition and switched off when dip beams come on...
Tomorrow i will try the center LEDs with the 4 pole relais...
Will post some photo's tomorrow... 2002 L322 V8
Post #341903 11th Aug 2015 9:01pm
