Home > General > Flappy Paddles - do you use them?
Vogue Owner
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Java Black
Can't say I've used my flappy paddles at all since I've had my FF , I think I used them once when I picked it up!
If you use them does the gearbox go back into D after a certain amount of time? CURRENT : FFRR 2012 4.4 TDV8
GONE : Discovery 4
GONE : BMW M5
GONE : L322 Range Rover
GONE : 2007 MITSUBISHI OUTLANDER
GONE : SAAB 9-3 VECTOR SPORT
GONE : BMW M3
GONE : SIERRA COSWORTH
GONE : LOTUS CORTINA
GONE : MK1 MEXICO
GONE : MK2 RS2000
Post #335608 2nd Jul 2015 7:54pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Rarely use mine either.
Automatically switches back to D after a little while. 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #335610 2nd Jul 2015 8:13pm
there's a dirty joke there somewhere.... Mr. Green ... - .- -.
Post #335616 2nd Jul 2015 8:40pm
supershuttle
My car doesn't have paddles, I sometimes use command shift or sport mode but like all SCs the car gets down the road quickly enough anyway and its not really designed to be driven like a sports car, it certainly doesn't handle like one Shocked Geoff
Post #335622 2nd Jul 2015 9:08pm
johnboyairey
I retro fitted some for my v8, as I have towed with another car, (a diesel) and found it annoying that you can either not 'lock-up', to cruise, or you have to kickdown to get a little 'passing speed' up, and then you are flying through, so if towing, they are useful, for those reasons, ie holding a gear longer whilst you go up an incline.
and would be useful descending a winding hill etc.
Lewis Hamilton racing starts are fine on straight roads, but not to be tried approaching/leaving roundabouts.
Post #335624 2nd Jul 2015 9:12pm
Used to use the manual setting on the 3.6, but that was handy for towing as it would then hold the gear for as long as it was selected or you speed dropped so low as to need the next gear down.
I have not towed with the 4.4 yet, but have played with the flappy bits a few times. It does switch back to d on its own, which when towing might be annoying! I wonder whether it will lock in to gear when the electrics are connected? There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #335636 2nd Jul 2015 10:17pm
ajac8
only used them a few times and purely for the hell of it. Nice toy to have if you feel like a change. It does change up when needed in any case so only ever really a semi manual. Changing back to D seems to be dependant on driving loads rather than just a standard time lapse.
If they dropped off tomorrow I wouldn't really miss them but nice. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #335637 2nd Jul 2015 10:26pm
Im not 100% sure but i think if you use “S” mode then the paddles they stay engaged until you re-select “D”... Thumbs Up
I as above have only ever used the paddles for towing, which is very handy Thumbs Up
Post #335641 2nd Jul 2015 10:47pm
Ive never used them - even for towing - i've not found the TDV8 to be lacking
On the L405 theres an option to disable them for D and have them only work in S - ive gone with that to stop me accidentally catching one.
Post #335647 2nd Jul 2015 11:27pm
Emperor Mong
On the L405 they can be forced back to D. Pull and hold the right paddle.
I only normally use them off-road going downhill. I occasionally use them on road but once in a blue moon.
I have paddles on my Aston and use those 100pct of the time. The paddles don't suit the rangie but do suit the Aston
Post #335654 3rd Jul 2015 5:49am
mzplcg
Yes, use mine all the time. The S/C engine can be a bit revvy when rowing it along so rather than let it rev higher I force the up change and use the torque.
Operationally they work as follows.
In 'D'. Use paddles and it reverts to D after 30 seconds of normal driving. If you're using the paddles to shift down for engine braking it waits until you accelerate and up change before starting the 30 second countdown.
In 'S'. Same as above except it never reverts to the S position unless you force it to.
Pulling and holding the right paddle for 30 seconds forces a reversion to D or S depending on what's selected on the knob or lever.
Post #335661 3rd Jul 2015 6:58am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
Used mine once to check they were working and never found a need for them even when towing.
Have occasionally hit one by accident.
Ian
Post #335666 3rd Jul 2015 7:29am
Interesting that you use the Aston paddles, given its the same 6 speed auto transmission as the L322. Albeit in the rear of the Aston Whistle
Post #335677 3rd Jul 2015 8:03am
Chaffers
United Kingdom 2013 Range Rover Vogue TDV6 Aintree Green
Yes, more often than I'd expected, but predominantly for engine breaking downhill, etc.
Post #335709 3rd Jul 2015 1:10pm
does the holding the + paddle work on the 322 too?
i just switch to sport and back to D if i want to cancel the paddles. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #335724 3rd Jul 2015 3:47pm
