![]() | Home > General > Flappy Paddles - do you use them? |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 ![]() ![]() ![]() |
Can't say I've used my flappy paddles at all since I've had my FF , I think I used them once when I picked it up!
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 ![]() ![]() ![]() |
Rarely use mine either.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
there's a dirty joke there somewhere.... |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3896 ![]() ![]() ![]() |
My car doesn't have paddles, I sometimes use command shift or sport mode but like all SCs the car gets down the road quickly enough anyway and its not really designed to be driven like a sports car, it certainly doesn't handle like one |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8750 ![]() ![]() ![]() |
Used to use the manual setting on the 3.6, but that was handy for towing as it would then hold the gear for as long as it was selected or you speed dropped so low as to need the next gear down.
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1665 ![]() ![]() ![]() |
only used them a few times and purely for the hell of it. Nice toy to have if you feel like a change. It does change up when needed in any case so only ever really a semi manual. Changing back to D seems to be dependant on driving loads rather than just a standard time lapse.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Im not 100% sure but i think if you use S mode then the paddles they stay engaged until you re-select D... |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
Ive never used them - even for towing - i've not found the TDV8 to be lacking
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
On the L405 they can be forced back to D. Pull and hold the right paddle.
Yes, use mine all the time. The S/C engine can be a bit revvy when rowing it along so rather than let it rev higher I force the up change and use the torque.
IanV8 Member Since: 14 Jan 2010 Location: Dunfermline Posts: 502 ![]() ![]() ![]() |
Used mine once to check they were working and never found a need for them even when towing.
Interesting that you use the Aston paddles, given its the same 6 speed auto transmission as the L322. Albeit in the rear of the Aston ![]() |
Chaffers Member Since: 04 Feb 2015 Location: South Bucks Posts: 14 ![]() ![]() ![]() |
Yes, more often than I'd expected, but predominantly for engine breaking downhill, etc. |
does the holding the + paddle work on the 322 too?
