![]() | Home > Technical (L322) > Gearbox issue.. |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 ![]() ![]() ![]() |
Which model do you own, James?
jamesbilluk Member Since: 27 May 2015 Location: Worcestershire Posts: 46 ![]() ![]() ![]() |
Hi Si
Glynn Member Since: 20 Sep 2013 Location: Lancs Posts: 64 ![]() ![]() ![]() |
Whatever you do DO NOT under any circumstances clear the gearbox adaptions !
Many thanks |
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1797 ![]() ![]() |
Any reason why? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 993 ![]() ![]() |
Dealers were told originally that before the transmission control software was reflashed they must reset the adaptions first. Problems then sometimes occurred if the clutches slipped excessively while trying to re-learn the new settings, causing the clutches to be permanently damaged.
