Home > Technical (L322) > Gearbox issue..
jamesbilluk
England 2007 Range Rover Supercharged 4.2 SC V8 Java Black
Gearbox issue..
Hi all,
Sorry for another question..
Ive recently become aware, when coming from a complete stop, it seems to be when the car is going from second to first, the car shunts forwards slightly, the change from first into second doesn't seem to be as smooth as it should be also.
To experiment, I put the car in to manual and kept it in second gear coming to the stop, I didn't get the shunt then.
The rest of the changes seem completely fine,
Is this something to worry about? the cars done 42000 miles, so not many miles on the gearbox
James.
Post #335392 1st Jul 2015 11:14am
Which model do you own, James?
You may add it to your profile so it's always visible. Thumbs Up
EDITED: SC, by the looks of it from previous posts.
From what I'm aware, it's a common gearbox trait that possibly a software update could cure. As you've no other problems, I don't see any great concern. Mine does it occasionally. Si. <This is my name.
Post #335393 1st Jul 2015 11:23am
jamesbilluk
Hi Si
Many thanks Smile Ah yes, forgot to put that, Yeah, Its a 2007 SC
Thats great to hear that its not mechanical, I'm due to take it somewhere for a check up soon, so will see if they can have a look,
Many thanks
James.
Post #335395 1st Jul 2015 11:38am
Glynn
United Kingdom 2005 Range Rover Vogue SE 4.2 SC V8 Zambezi Silver
Whatever you do DO NOT under any circumstances clear the gearbox adaptions !
or even interfere with any gearbox electronic settings.
You have been warned !.
Believe me, I have been there and never again.
Post #335409 1st Jul 2015 1:03pm
jamesbilluk
Many thanks Smile Shall stay away from the gearbox settings, and the adaptions too.
Post #335439 1st Jul 2015 6:28pm
Mikey
Any reason why?
Post #335447 1st Jul 2015 7:18pm
RRPhil
Dealers were told originally that before the transmission control software was reflashed they must reset the adaptions first. Problems then sometimes occurred if the clutches slipped excessively while trying to re-learn the new settings, causing the clutches to be permanently damaged.
Phil
Post #335479 1st Jul 2015 10:00pm
