Home > General (L405) > 5.0 SC Driving Differences
Page 1 of 3 123>
carlos50
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
Hi all
Other than being faster does the 5.0 SC drive any differently in terms of handling than the SDV8? I recall the first of the L322 4.2 SC models had thicker roll bars, greater damping forces in the airbags and better brakes, is this a similar trend for the L405 compared to the SDV8?
Just keen to know if my aspirations should be a 5.0 after the 4.4 and deffo don't want to drive it yet because I cant afford the extra £15k yet.
Thanks
Carl
Post #332057 11th Jun 2015 4:34pm
Nick Ground
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Indus Silver
I don't think there are any differences in brakes (only 3.0 seems to have smaller front discs) or suspension. In theory the SC is slightly lighter than the SDV8 but that can be all about options and trim. On the road differences seem small, maybe sc turns in a bit better, and that the sc squats down more under hard acceleration, no surprises there really as both have active dynamics.
Nick 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
gone 17 older variants of FFRR
Post #332066 11th Jun 2015 5:29pm
carlos50
Thanks Nick.
Im a petrol head at heart and fancy a 5.0 in a year or so, for the much better acceleration feel if nothing else, just wondered if it drove flatter, as a bonus Very Happy
Carl
Post #332176 12th Jun 2015 11:52am
Philip
Assume the anti-roll, damping etc. calibration will be different due to the lighter engine. As Nick says, you would expect it to be a little lighter on its feet because of that (similar to TDV6/SDV8 differences).
Post #332177 12th Jun 2015 12:03pm
Nick Ground
I am a petrolhead too and am pretty sensitive to handling I can feel the difference in damping setting, tyre pressures etc on my MX5 track day car). There is a big difference from 3.0 to 4.4 emphasised by the active suspension fitment on bigger engine. The handling differences are very much smaller between 4.4 and 5.0 (I have driven 45k miles in 4.4SDV8's). I've only had my 5.0 for 2500 miles and it takes a little while to get past the really noticeable differences such as initial impressions of less torque and busy gearbox, the OMG when you stab at pedal expecting turbo lag, NVH and increased familiarity with petrol retailers. To really quantify a difference you would need to back to back drive the same corners, or just maybe ask someone with the full diagnostic kit to see if there is a separate dynamics setting for the SC.
The real difference is the much less intrusive engine and resultant quiet cruising. In a real world cross country drive I doubt the 4.4 would be any slower or that you would notice any handling differential. They are both unfeasibly swift for a 4x4 and both will lose you your license if you took full advantage.
55 D3 SE
98 MX5 1.8 RS
Post #332183 12th Jun 2015 12:37pm
Philip
Yes, I probably didn't phrase that very well - any differences due engine weight are no doubt far less obvious when both have active anti-roll.
Post #332193 12th Jun 2015 1:52pm
Nick Ground
Hi Trommel,
I think my reply was more for the OP anyway. But yours is a valid observation.
Nick. 2019 D5 HSE Lux SDV6 Indus
55 D3 SE
98 MX5 1.8 RS
Post #332199 12th Jun 2015 2:45pm
carlos50
Thank you both, Im considering a tune to reduce turbo lag and give it some more oomph, that may well be the best of both worlds then?
I like the engine tone of the SDV8 and drive in manual a fair bit, and sport all the time.
Post #332260 12th Jun 2015 8:24pm
Aeroresh
2014 Range Rover Vogue SDV8 Nara Bronze
If youre looking at tuning the sdv8 DMS is your friend Thumbs Up '14.5 SDV8 Nara Bronze for sale
'17 BMW 740e Msport Individual on order
'17 Jeep Grand Cherokee SRT 6.4 Hemi on order
'16 Bentley Continental GT V8S Mulliner Driving Spec
'07 Alfa 159 3.2 Q4
'05 Mini Cooper R50
'95 Volvo 850R modified to 400hp
'89 Jaguar TWR ed XJ-S V12 Convertible
Post #332296 13th Jun 2015 7:34am
Philip
No remap is going to reduce turbo lag though.
Post #332315 13th Jun 2015 10:21am
carlos50
Its been suggested that it can be tuned out somewhat. Not removed but improved, don't you agree?
Post #332318 13th Jun 2015 11:09am
It cab definitely help - on my 3.6 there was a low end flat spot that a BAS remap smoothed out and made it much smoother (and quicker) off roundabouts.
I haven't felt the need to fiddle with the SDV8 though Thumbs Up
Post #332345 13th Jun 2015 1:39pm
I think you'll maybe find the front end suspension setup is the same between them but the firmware for the active suspension is different to account for the weight difference but also more likely to account for expected driving styles of the vehicles as the sc is more likely to be seen by purchasers and owners.... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #332392 13th Jun 2015 10:20pm
My old 3.6 was mapped by BAS too and the lag had almost been eliminated... Mr. Green
Post #332407 13th Jun 2015 11:41pm
carlos50
Thanks for all the comments, I came out of a 2011 Cayenne Turbo so can feel the lack of low down pull. When the SDV8 gets into its stride in manual mode it pulls well and I wonder if the extra 100 Nm of torque and reduced lag might help get the best of both worlds - a much nicer car to drive overall and sit in but with a performance not a million miles away from the Porsche in Norma driving mode (not sport which was just insane).
As I said the 5.0 was too expensive when the extra purchase cost and much lower mpg are taken into account so the SDV8 was the only option for me, and I just think it needs a bit more low down.
Will let you know what it does if I get the tune done?
Thanks
Carl
Post #332426 14th Jun 2015 10:17am
Page 1 of 3 123>
