Home > Technical (L322) > Air suspension compressor.. are there different types ? |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 |
Hi, the air suspension compressor on my car has given up so i thought rather than mess about with it i would just order a new one from island 4x4 It turned up today , i just removed everything from my boot and its different to the one currently in my car.
26th Nov 2014 1:46pm |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2257 |
26th Nov 2014 2:42pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
Although your car is an '05' it must be a MY2006.....that explains the difference. Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
26th Nov 2014 3:49pm |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
55 plate is around the change over, my 55 plate is an 06 model with the facelift and touchscreen (AJV8 engine as well but see you are diesel so i think the engine did not change). If you have the facelift smaller one piece lights and grill and touchscreen you will have the 06 model. If you have touchscreen and the bigger two piece lights then it is a changeover model using some BWW and some Ford bits so not as clear which model to choose for parts etc. There is a difference between knowing your sh!t and knowing you're sh!t
26th Nov 2014 3:54pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Hi ya bud, think you might have the wrong unit, I think that 2005 was the change over year, if your compressor has the 2 blue pipes then it's a Hitachi unit not the Wabco that's in a round dome like container for up to chassis number 5A999999. The Hitachi unit goes on chassis number 6A00001 on wards.
26th Nov 2014 4:03pm |
Thanks for your great advice is much appreciated, i just checked my vin and it is a 6A------- Teach me not to check the item i'm changing first Are the Hitachi units prone to failing as much as the earlier types? as most of the ones i find for sale are the round wabco ones. |
26th Nov 2014 4:59pm |
Sorry Bud, but I'm not in a position to answer that one, as I have the Waboc unit. However I will say that if the Hitachi is anything like the Wabco, it will only have a small piston whizzing up and down frantically trying to keep up with the pressure demands of the suspension. If you use the low exit button or regularly go in to off road mode, you is going to ware it out quicker. Having said that just going over 60 Mph will cause the car to lower it's self, and therefore will require air to return to normal height. Then there is the well sealed nature of the air suspension, is it any wonder that the compressor gives up?
27th Nov 2014 3:01pm |
yes i think your right, everytime i park up at my house i put the car into access mode when i get out, maybe i shouldnt do this so much and just let the misses jump down from up high |
27th Nov 2014 3:53pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6366 |
Just went through something similar with my mum's new (to her) RRS SC, as the compressor had gone.
27th Nov 2014 5:48pm |
Bang in under a second, that is what I call premature! Yesterday I couldn't spell Engineer... Today I are one!
27th Nov 2014 5:56pm |
Are the ones from LR not Hitachi also then mate? |
27th Nov 2014 6:11pm |
Not sure, I never saw the unit Discovery 4 HSE
27th Nov 2014 6:15pm |
Yes they are, Hitachi are OEM for the later FFRR's Yesterday I couldn't spell Engineer... Today I are one!
27th Nov 2014 7:16pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Hitachi were dropped by Land Rover in favour of another manufacturer (three letters, but i cannot remember at this time of night what they are)
27th Nov 2014 10:03pm |
