Home > In Car Electronics (L322) > TV upgrade
what you have to consider jason is that you need to be in a location where the signal is strong to receive channels, weak signal will limit channels and those you do pick will suffer from breakup due to passing vehicles etc....
remember you only have window antennas and although the FF is taller than the average car , its not as tall as a house with an ariel on top of the chimney.. ...
also consider that the tv can only be used when stationary and in park and the FF's battery isnt that good so you might drain it.. ... - .- -.
Post #331778 10th Jun 2015 7:33am
DannyH
England 2002 Range Rover HSE 4.4 V8 Zambezi Silver
welcome to the forum both of you.
p.s. no one was offended, don't worry. Dan
2002 Zambezi Silver
Men And Motors RR Quote - It's like having wheels fitted to your living room!
Post #331780 10th Jun 2015 7:38am
RRwalker77
England 2005 Range Rover Autobiography Td6 Java Black
cracking info thanks i take it you still get extra dab radio but im presuming that only works on tv mode?
Post #331791 10th Jun 2015 8:17am
Zirconblue
RRwalker77 wrote:
does yours work fine then zirconblue? any issues? is it just a straight plug an play? do u get all channels etc?
thank in advance
It was pretty much plug and play yes, i did notice a setting in the IID tool to change the TV type, but i'm not sure what it did as it was working to start with.
As stan says you need a reasonably strong signal for it to be watchable, As soon as you select R or D the picture is obscured but you can still listen to the sound which worked quite well when i tested it the other day.
I don't think you get the radio channels like you do on a TV but i've not looked that far through the channels yet, i'd have to check.
Post #331798 10th Jun 2015 9:18am
^ unfortunately the radio channels are not available on the FF tuner, why i dont know and i suspect its a software problem. ... - .- -.
Post #331803 10th Jun 2015 9:36am
PaulB
2017 Range Rover Autobiography SDV8 Loire Blue
Morning
If anybody is interested i have just removed my tuner from my 2005 touchscreen, 100% working.
Im chopping the car in against a newer model and i am looking to sell the tuner.
Regards
Paul
Post #331806 10th Jun 2015 9:41am
it is the digital one yes? ... - .- -.
Post #331808 10th Jun 2015 9:43am
PaulB
Yes Stan.
I installed it alongside the old one last year.
I have removed it and plugged the old one back in.
Regards
Post #331897 10th Jun 2015 7:46pm
Thumbs Up ... - .- -.
Post #331920 10th Jun 2015 8:47pm
