![]() | Home > In Car Electronics (L322) > TV upgrade |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35605 ![]() ![]() |
what you have to consider jason is that you need to be in a location where the signal is strong to receive channels, weak signal will limit channels and those you do pick will suffer from breakup due to passing vehicles etc....
RRwalker77 Member Since: 09 Jun 2015 Location: bideford Posts: 5 ![]() ![]() ![]() |
cracking info thanks i take it you still get extra dab radio but im presuming that only works on tv mode? |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It was pretty much plug and play yes, i did notice a setting in the IID tool to change the TV type, but i'm not sure what it did as it was working to start with. As stan says you need a reasonably strong signal for it to be watchable, As soon as you select R or D the picture is obscured but you can still listen to the sound which worked quite well when i tested it the other day. I don't think you get the radio channels like you do on a TV but i've not looked that far through the channels yet, i'd have to check. |
^ unfortunately the radio channels are not available on the FF tuner, why i dont know and i suspect its a software problem. ... - .- -.
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 ![]() ![]() |
Morning
it is the digital one yes? ... - .- -.
Yes Stan.
