Home > General (L405) > L405 move drivers seat on opening the car ?
On my L322, the seat would be set automatically as I unlocked it based on which key I opened the car with.
My L405 doesn't seem to do this - I have to select the seat position after my wife has been driving it (& vice versa) - even though we have our own key.
Is this normal ? I can't find anything in the manuals
Post #327817 13th May 2015 9:23pm
Strange!!! Im sure they adjust when i open customers doors Neutral Confused
Post #327821 13th May 2015 9:31pm
RiccartonRR
Am I wrong or isn't this called Lazy Entry and can be turned on / off via the on-board computer??
I'm sure it can on the L322 but I keepp mine turned off as we share a driving position anyway.
Post #327823 13th May 2015 9:35pm
I'll look for lazy entry
I'm sure it must be a setting somewhere - I just can't find it Embarassed
Post #327827 13th May 2015 9:41pm
Ahhh yes you are right sir Bow down Bow down Bow down Thumbs Up
Post #327835 13th May 2015 9:52pm
rr driver
United Kingdom 2011 Range Rover Autobiography 5.0 V8 Santorini Black
On the L322 it is called Easy Entry/Exit and is activated by the controls on the instrument panel. 2011 5.0SC Santorini Black
2009 5.0SC Santorti Black - Been stolen.
Had
2.5 DHSE P38
Alfa Romeo
BMW
Post #327840 13th May 2015 10:30pm
RRVSE
United Kingdom 2013 Range Rover Vogue SDV8 Corris Grey
Also, if you want the steering wheel to 'move out of the way' when you turn the engine off to help with entry/exit, you need to make sure the steering wheel adjuster knob is turned to the automatic position else it stays where it is i.e. only moves when you select a memory seat position or move it manually. Steve
Main car : FFRR L405 Vogue SDV8
Other car : Vauxhall Lotus Carlton
Past cars : FFRR L322 Vogue TD6 SE (Sept 2006 MY07) ; LandCruiser SWB ; 4-Runner ; Supras; XJS V12 LeMans
Post #327900 14th May 2015 12:26pm
Thanks - I found the steering wheel thingy - just haven't been able to figure the seats - will have another look through the menus tonight Thumbs Up
Post #327906 14th May 2015 1:14pm
ebajema
It may be something that you need an IID/Faultmate or similar tool for. I remember switching it all on with my Faultmate on the 4.2. Steering and seat are separate settings IIRC. MY 2010 5.0 SC Galway green and sand interior!!
Post #327913 14th May 2015 2:00pm
Big Cry I can't find anything in the menu's
Everything else is there - drive away locking, 2 stage unlocking, headlight delay etc. seems odd that they would leave this one out.
Oh well, I guess I'll be calling the dealer tomorrow
Post #327979 14th May 2015 8:54pm
Ms. Mdx
United States 2015 Range Rover Autobiography 5.0 SC V8 Scotia Grey
L405 - The keys are the same and you don't have Driver-1 and Driver-2 settings tied to each different key. You need to press the seat memory button you have programmed to get your seating position to adjust. When you use Convenience mode, it remembers the last seat position that was selected from the seat memory buttons ... so if you are tall and your wife is short and she had just been driving last, you might find yourself being compacted if you don't press your memory seat number. I think LR used 10+ year old technology on this one! Rolling Eyes
CONVENIENCE MODE
When the door is opened using either the Smart
key or Passive entry, the vehicle's electrical
system initiates the convenience mode. The
following systems become functional:
• Seat and steering column adjustment.
• Interior and exterior lighting.
• Message center.
• Auxiliary power socket. 2015 RR ATB (Scotia Grey w/Cirrus-Ebony)
2014 MB E63 s/AMG
2010 Acura MDX
Post #328145 16th May 2015 5:06am
Thanks - that's the behaviour I'm experiencing - massive step backwards IMHO Big Cry
One of the really nice features of the L322 was that by the time I got in, the seat was in the right place for me even after my wife had been driving.
Post #328239 17th May 2015 7:32am
RRV
United Kingdom 2015 Range Rover Vogue TDV6 Santorini Black
Yes I found this out too. Very annoying considering that I had this feature on my 2003/05/07 and 12 but not my 2015! Shocked If you have nothing nice to say,say nothing at all.
Post #328256 17th May 2015 10:02am
RRVSE
One good thing with the L405 if you are the sole driver, is that as you turn the engine off the seat moves back and down and the steering wheel up and out of the way for ease of access and then when you get back in and press the engine start, it goes back to the last memory position (as already stated), my L322 only used to move the wheel out of the way and left the seat where it was , so it has improved in 1 respect but gone backwards in another Sad Steve
Post #328444 18th May 2015 12:32pm
09> 322's move the seat as the 405's do sir Thumbs Up
Post #328448 18th May 2015 12:37pm
