![]() | Home > General (L405) > L405 move drivers seat on opening the car ? |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16339 ![]() ![]() ![]() |
Strange!!! Im sure they adjust when i open customers doors |
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Am I wrong or isn't this called Lazy Entry and can be turned on / off via the on-board computer??
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8001 ![]() ![]() ![]() |
I'll look for lazy entry
Ahhh yes you are right sir ![]() ![]() ![]() ![]() |
rr driver Member Since: 09 Dec 2013 Location: london Posts: 181 ![]() ![]() ![]() |
On the L322 it is called Easy Entry/Exit and is activated by the controls on the instrument panel. 2011 5.0SC Santorini Black
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
Also, if you want the steering wheel to 'move out of the way' when you turn the engine off to help with entry/exit, you need to make sure the steering wheel adjuster knob is turned to the automatic position else it stays where it is i.e. only moves when you select a memory seat position or move it manually. Steve
Thanks - I found the steering wheel thingy - just haven't been able to figure the seats - will have another look through the menus tonight |
It may be something that you need an IID/Faultmate or similar tool for. I remember switching it all on with my Faultmate on the 4.2. Steering and seat are separate settings IIRC. MY 2010 5.0 SC Galway green and sand interior!!
Ms. Mdx Member Since: 14 Feb 2015 Location: CA Posts: 62 ![]() ![]() ![]() |
L405 - The keys are the same and you don't have Driver-1 and Driver-2 settings tied to each different key. You need to press the seat memory button you have programmed to get your seating position to adjust. When you use Convenience mode, it remembers the last seat position that was selected from the seat memory buttons ... so if you are tall and your wife is short and she had just been driving last, you might find yourself being compacted if you don't press your memory seat number. I think LR used 10+ year old technology on this one! |
Thanks - that's the behaviour I'm experiencing - massive step backwards IMHO |
RRV Member Since: 05 Oct 2009 Location: Midlands Posts: 648 ![]() ![]() ![]() |
Yes I found this out too. Very annoying considering that I had this feature on my 2003/05/07 and 12 but not my 2015! |
One good thing with the L405 if you are the sole driver, is that as you turn the engine off the seat moves back and down and the steering wheel up and out of the way for ease of access and then when you get back in and press the engine start, it goes back to the last memory position (as already stated), my L322 only used to move the wheel out of the way and left the seat where it was , so it has improved in 1 respect but gone backwards in another |
09> 322's move the seat as the 405's do sir |
