![]() | Home > Maintenance & Mods (L322) > reconditioned or second hand engine |
3.0 TDV6??? |
cl0ud Member Since: 10 May 2015 Location: United Kingdom Posts: 10 ![]() ![]() |
yeah the 3.0 |
Bottom end? |
Given the amount of work involved in removal and refitting I would always go down the reconditioned route. Especially so on a FFRR where it's all rather crammed in. You really do want to know what you're putting in is going to be good, or at least minimise the risks of fitting a duffer.
The reason i asked if it was bottom end is there is a well known issue with 3.0 TDV6 or SDV8 engine self destructing! |
CSK Member Since: 15 Oct 2010 Location: St Tropez Posts: 750 ![]() ![]() ![]() |
Maybe he could start with a little introduction of himself as he joined us only 3 days ago! It would be nice to get to know you, your car and the exact problem you are encountering. Isn't a forum about sharing?
Not heard of L405 3.0 engines failing sir!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35514 ![]() ![]() |
i suspect this is for a L322 so i've moved it, if i'm wrong can someone tell me please... ... - .- -.
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
It depends on how you come by the second hand engine. If you can buy the complete scrap (presumably accident damaged car) then you'll be able to test the engine yourself and probably be able to find something about the service history.
RiccartonRR Member Since: 12 Jul 2014 Location: Scottish Borders Posts: 724 ![]() ![]() |
Stan - did an L322 ever have a 3.0 TDV6 fitted or are you thinking he means the TD6?
Rangeyman Member Since: 03 Feb 2015 Location: west yorkshire Posts: 267 ![]() ![]() ![]() |
Why would anyone fit a secondhand unknown engine instead of recon unless there was a serious price difference but to get a big price difference it must be a bag of crap!! |
wow, thank you so much for all the responses guys.
Well I can understand the feedback you're getting. The bulk reconditioning places are very much "Pile 'em high & Sell 'em cheap" with the expected levels of quality. When the guys bolting them back together are on piecework rates you do find a lot of poor workmanship.
Agreed mzplcg. We've had some pretty shocking experiences ourselves. Worst one we had was an engine we ordered for a customer which upon installation had no compression. And when the customer opened the engine up, he found that it was a used engine that was simply sprayed from the outside to make it look like a recon. Subsequently the company went into liquidation and we were left with the entire repair bill.
