Home > Technical (L322) > Reliabilaty issues on 2012 model year FFRR Vogue TDV8 4.4 |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16263 |
Was that a miss type? TDV6 FFRR sir |
4th May 2015 11:05pm |
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 |
says TD6 Vogue in his signature, so i would say so. |
5th May 2015 3:13am |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1372 |
My 2012 Westminster (25,000 miles) has had:
5th May 2015 1:58pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1652 |
Flippin eck CS you got a Friday afternoon car there by the looks of things. Glad to see the warranty has come to your aid. I do second the paintwork on the lower tail gate issue. Mines a 2011 MY and disappointed to see it starting to bubble only slightly for now.. Other than that I've had no issues but I've only had the car 6 months. Just about to break 80K and going smooth.
5th May 2015 3:54pm |
RJH Member Since: 22 Mar 2015 Location: Coventy Posts: 398 |
Hi,
5th May 2015 8:31pm |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8164 |
It's amasing isn't it.... my 2003 has absolutely no rust on either tailgate and yet time and again we see these posts about cars 10 years+ younger... what have they done, added salt to the paint!!!!! Pete
5th May 2015 10:14pm |
Ford took over in 2005 Pete... |
5th May 2015 10:20pm |
CEEGEE Member Since: 20 Mar 2013 Location: Yorkshire Posts: 685 |
I've had my 2010 MY 3.6 TDV8 for 6 months and I've had no problems at all
5th May 2015 10:49pm |
Diver Bryn Member Since: 16 Jan 2012 Location: Durham Posts: 34 |
Sold my 2005 (Purchased from new) TD6 Vogue with 150K on Clock and absolutely brilliant mechanically. Rust blebbing through rear wheel arches (even after LR replaced the rear offside wing under warranty) Replaced front air suspension arms x 2 and normal service cost's. Looked at replacing it with Tourag's, XC90's, ML's, Audi's Q7 and yet nothing comes remotely close to the Rangee luxury, by the time you build other manufacturers products up to same Range Spec! Now on route to look at striking a deal on a 2014 TD6 Vogue new shape. Happy days! Diver Bryn
6th May 2015 7:28am |
stoutgoose Member Since: 08 Jan 2015 Location: London Posts: 186 |
Turbo drain pipe modification.
6th May 2015 8:30am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3736 |
Nothing other than the tailgate bubbling rubber window trim - best car I have had ! (So far!!!) 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17 |
6th May 2015 6:45pm |
cloudwind Member Since: 01 Nov 2011 Location: Hertfordshire Posts: 20 |
Same as previous poster Vogue with the rear screen trims, no big deal. Also had a drive belt pulley making a noise which was duly fixed without issue under warranty by Lookers Bishops Stortford. Thumbs up to them
6th May 2015 6:56pm |
Out of interest how did the gearbox failure manifest itself? I thought these new 8 speed gearboxes were fairly robust? |
7th May 2015 6:21pm |
What happened is that about 2 litres of gearbox oil leaked form where the gearbox and engine meet. The gearbox had continued to work as normal but LR decided that it should be replaced, perhaps because the loss of fluid might make it uncertain whether it would be OK in future. Only Range Rovers since 1988 |
7th May 2015 10:08pm |
