Home > Technical (L322) > Reliabilaty issues on 2012 model year FFRR Vogue TDV8 4.4
Diver Bryn
United Kingdom 2005 Range Rover Vogue Td6 Tonga Green
Just Sold my FFRR TDV6 Vogue. looking at purchasing, a 2012 model year FFRR Vogue TDV8 4.4. Any one had any warranty issues thus far?
I understand turbo's in old versions were prone to giving up the ghost?? Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Renault Fuego 2 ltr TX
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Volvo 740 TDi Estate
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Land Rover Discovery 3 TDV6
Mini Cooper Diesel
Mercedes Vito Van 111
Range Rover TD6
VW Golf 2ltr GTD 2015 Year
2016 Audi Q7 Sline 3ltr 272Bhp
Post #326030 4th May 2015 10:28pm
Was that a miss type? TDV6 FFRR sir Rolling Eyes
Post #326033 4th May 2015 11:05pm
Zirconblue
says TD6 Vogue in his signature, so i would say so.
Post #326038 5th May 2015 3:13am
CS
My 2012 Westminster (25,000 miles) has had:
- new gearbox
- fuel burning heater software fault leading to battery drain, new battery required
- locking software fault leading to battery drain, battery could be revived
These all involved loss of vehicle use and were fixed under warranty.
Also rear brake caliper seizure, fixed at my expense
Trim issues fixed under warranty not involving loss of use:
- corrosion on wheels, new wheels supplied
- corrosion on window frame, new panels supplied
- leaking rear door seal, fixed by repositioning I think
- ill fitting rear door curved edge rubber, new rubber supplied
- corrosion on trim along sides of rear tailgate window, new trim supplied
-buzzing and rattling from behind dashboard, fixed by rebuilding (twice)
Trim issues now existing and to be complained about at next service
- window frame corrosion again
- bubbling in paint on either side of upper tailgate, bottom edge along from number plate lights, this seems a known fault going by threads elsewhere on here
- corrosion to upper tailgate damper struts
- corrosion to wheel centre badges (maybe some contribution on my part as these are swapped between the 19" and 20" wheels summer and winter)
I had been thinking of operating a 'three strikes and you're out' policy with this one, following the exasperating and costly series of failures on my last 322, but have not found anything else that meets my needs as well, so on we go...still under warranty, but I see the Sad cost of extending this plus LRA for another year is £1200... Only Range Rovers since 1988
Post #326122 5th May 2015 1:58pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Flippin eck CS you got a Friday afternoon car there by the looks of things. Glad to see the warranty has come to your aid. I do second the paintwork on the lower tail gate issue. Mines a 2011 MY and disappointed to see it starting to bubble only slightly for now.. Other than that I've had no issues but I've only had the car 6 months. Just about to break 80K and going smooth.
It would be worth finding out if the turbo pipe mod has been done (plenty of info on this but this is a good info thread:http://www.fullfatrr.com/forum/topic29786.html) Known issue to LR but it seems fixed as and when rather than sorted on production line.
Good luck Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #326130 5th May 2015 3:54pm
RJH
England 2011 Range Rover Vogue TDV8 Santorini Black
Hi,
Had mine since January & only warranty issues have been a couple of oil pipe leaks on turbo oil pipe & oil cooler plus the fuel sender failed so it showed half full as it always does anyway Rolling with laughter
Did have water issue in the PDC module, that caused it to fail. I think (finger crossed) that was down to condensation as I've not been able to replicate the fault & can't find any signs of water ingress. Whistle
Good luck with the search Thumbs Up 2011 (MY12) 4.4 TDV8 Vogue
2016 Golf GTI PP
Gone
Audi A4
VW Passat
VW Corrado G60
VW Golf GTI
BMW E30
Mini
Vauxhall Chvette
Post #326185 5th May 2015 8:31pm
It's amasing isn't it.... my 2003 has absolutely no rust on either tailgate and yet time and again we see these posts about cars 10 years+ younger... what have they done, added salt to the paint!!!!! Pete
Post #326209 5th May 2015 10:14pm
Ford took over in 2005 Pete... Whistle
Post #326212 5th May 2015 10:20pm
CEEGEE
I've had my 2010 MY 3.6 TDV8 for 6 months and I've had no problems at all Thumbs Up
Locking wheel nuts are rusting and could do with replacing, one very insignificant advisory that I can't even remember from an over zealous tester and that's it - happy days (he said tempting fate) Whistle
Post #326221 5th May 2015 10:49pm
Diver Bryn
Sold my 2005 (Purchased from new) TD6 Vogue with 150K on Clock and absolutely brilliant mechanically. Rust blebbing through rear wheel arches (even after LR replaced the rear offside wing under warranty) Replaced front air suspension arms x 2 and normal service cost's. Looked at replacing it with Tourag's, XC90's, ML's, Audi's Q7 and yet nothing comes remotely close to the Rangee luxury, by the time you build other manufacturers products up to same Range Spec! Now on route to look at striking a deal on a 2014 TD6 Vogue new shape. Happy days! Diver Bryn
Previous Transport:
Honda CB250n
Toyota Starlet
Fuego Turbo
BMW 528i
Escort RS Turbo
Capri 2.0 L Ghia
Kawasaki GT750 P4
Mini Metro
Ford XR2
Mondeo Tdi
Volvo V70 Tdi
Mercedes E300 TDI
Mercedes E320 Cdi
Mercedes S320 Cdi
Mini Cooper Diesel
Range Rover TD6
Post #326248 6th May 2015 7:28am
stoutgoose
United Kingdom 2012 Range Rover Westminster 4.4 V8 Zermatt Silver
2012 4.4 TDV8 57,000 miles
Turbo drain pipe modification.
Rear tailgate window side rubber trims replaced due rust in old trim clips.
A/C compressor replaced.
Oil pump replaced due to 'shimmying' noise. You can still hear the noise albeit a lot quieter, so I'm not convinced it was the oil pump.
Bubbling paint in centre of N/S rear door.
Wheel centre caps corroding.
TV screen.
All work done under warranty. I'm glad I have another two years LR extended warranty left when the manufacturer's warranty runs out in January next year!
Post #326267 6th May 2015 8:30am
Vogue
Nothing other than the tailgate bubbling rubber window trim - best car I have had ! (So far!!!) 2021 L405 Vogue SE 4.4 V8 DIESEL ~ #17
Post #326419 6th May 2015 6:45pm
cloudwind
Same as previous poster Vogue with the rear screen trims, no big deal. Also had a drive belt pulley making a noise which was duly fixed without issue under warranty by Lookers Bishops Stortford. Thumbs up to them
Just sold vehicle and it was the most reliable car I have owned over last 3 and a half years, shaming the previous Mercs and Audis which all let me or the Mrs down on at least one occasion each. The RR never once failed us.
Nigel
Post #326422 6th May 2015 6:56pm
stoutgoose
Gearbox failure.
- new gearbox
- fuel burning heater software .....................................................
Out of interest how did the gearbox failure manifest itself? I thought these new 8 speed gearboxes were fairly robust?
Post #326572 7th May 2015 6:21pm
CS
What happened is that about 2 litres of gearbox oil leaked form where the gearbox and engine meet. The gearbox had continued to work as normal but LR decided that it should be replaced, perhaps because the loss of fluid might make it uncertain whether it would be OK in future. Only Range Rovers since 1988
Post #326620 7th May 2015 10:08pm
