Home > Maintenance & Mods (L322) > Help with rounded locking wheel nut
Page 1 of 3 123>
supershuttle
I have had a quick search but I couldn't find anything definitive, the situation is I have a rounded locking wheel nut not the outer bit but the inner bit. So the outer bit will turn yes, but the inner bit which appears to be made of a softer metal has rounded so everything spins but of course nothing unscrews.
It started of as such a normal day as well, the stuff arrived to do my calipers but this locking nut says otherwise good job I have time to waste and good job it isn't a puncture by the side of the road. I've put everything back together and torqued up the other 4 nuts so car is drivable but is fixing this DIY or are there specialists I can take it to? Geoff
Post #325152 30th Apr 2015 5:10pm
markcaughey
Scotland 2006 Range Rover Vogue 4.4 V8 Buckingham Blue
Try gumtree search locking wheel nut removal. A lot of independent garages offer this service. Polish guy round the corner from me is an expert I have referred several people to him he has them off in seconds. He charges £10 a wheel I think it's well worth it rather than messing with it yourself for hours and possible damaging the wheel.
as you say if you get a puncture then your Censored and if it's not that it's usually the rest of the nuts are so overtightened that they are impossible to get off without a huge bar to jump on because some grease monkey has put them far too tight and not to correct specs . Every time I get a new car that's the first thing I do remove all wheel nuts and locker, get some anti seize on them and put them to the correct torque setting Thumbs Up so many people must get caught out with this at the side of the road when they get a flat ! Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #325159 30th Apr 2015 6:10pm
viper
United Kingdom 2007 Range Rover Vogue TDV8 Zermatt Silver
what is the torque for wheel nuts out of interest
Post #325162 30th Apr 2015 6:42pm
markcaughey
105 ft lbs / 142Nm . i set mines at 150nm and the locking nut i left slightly looser Range Rover Vogue 2006 4.4 AJV8 | Buckingham Blue | Parchment Leather | Supercharged Grill+Side Vents | CA02 HEY ( NOT 02 PLATE )
Post #325169 30th Apr 2015 6:57pm
SKOT
England 2006 Range Rover Supercharged 4.2 SC V8 Bonatti Grey
......and then throw the lockers in the bin. Far more trouble than they are worth in my view. 2006 4.2 SC
2019 Renault Zoe Dynamique Nav
Post #325170 30th Apr 2015 6:58pm
supershuttle
I binned the last lot from previous car, this is obviously episode two "The revenge of the Locknuts"
I think I will use someone who knows what they are doing to get it off - better the practised man than the man who needs the practise - Very Happy Geoff
Post #325182 30th Apr 2015 7:44pm
zoso
Scotland 2013 Range Rover Autobiography SDV8 Santorini Black
You can buy a socket from Halfords which removes stripped locking nuts but, obviously, it completely wrecks the nut. They have several different sizes though so I would take one of the good ones with you. Worked fine for me one of my Disco 3 wheel nut.
I have since abandoned the locking wheel nuts - more trouble than they're worth !! 2017 4.4 TDV8 Autobiography
2016 4.4 TDV8 Autobiography - GONE
2013 4.4 TDV8 Autobiography - GONE
2010 3.6 TDV8 - GONE
2008 3.6 TDV8 - GONE
2002 3.0 TD6 - GONE
2006 Discovery 3 TDV6 S - GONE
2006 Discovery 3 TDV6 - GONE
2003 Discovery 2 TD5 - GONE
1999 Discovery 300 TDI - GONE
1998 Range Rover DSE - GONE
1997 Discovery 300 TDI - GONE
Post #325204 30th Apr 2015 9:45pm
Rangeyman
My 2004 model has 'Torx' type lockers but as the example above I believe there is a weakness here,my mate had one he couldn't get off but it was the tool that looked worn as well,after lots of spray and plenty hammer he rang the local dealership to get another tool.While he was there they loaned him their tool to check it was the correct one so he tried it and it came straight off.Maybe the spray /hammer had done the best bit but he then bought a new tool which looked so much better than the old one.By this time the locker didn't look too good with the rear part slightly rounded but to get another he had to buy all 4 which were not cheap at all.I suggested putting some weld on the rounded part and grind square so giving a great new fit.Needless to say we took off all 4 lockers and liberally applied copper grease and not to mad with the wrench,Job done!!
Post #325212 30th Apr 2015 10:38pm
Re: Help with rounded locking wheel nut
Geoff, be aware these are made of a VERY hard material and needs drilling with specialist kit to remove them! Speak to an experienced specialist my friend as there are lots of pitfalls with removing them!
Post #325217 30th Apr 2015 11:18pm
miggit
Geoff what sort of wheel nut are we talking about? Is it one with hole in the middle that you put the star key into, in which case I can confirm that they are cr-p. On the bright side there is no way that anyone will nick your wheels, on the down side there is no way you can change your wheels Evil or Very Mad
I would find a torks bit or allen bit that's just too big and hammer it in to the wheel nut, then very gently try and undo it. it would probably help if you loosen the other nuts off first. After you've hammered one size in it's easy to go up to the next size if the first starts to slip.
Remember that the key to nackered nuts is a big hammer Shocked Big Cry Yesterday I couldn't spell Engineer... Today I are one!
Post #325221 30th Apr 2015 11:28pm
Geoff will have this type on his car!
http://www.ebay.co.uk/itm/RANGE-ROVER-disc...3cc356f626
NOT this type, i think you are referring too on the early models!
http://www.ebay.co.uk/itm/BMW-locking-whee...4194e2d42a
Post #325223 30th Apr 2015 11:37pm
supershuttle
Paul - Craig's right they are unfortunately not the Torx type
Craig I'm thinking of this guy www.thewheelnutman.co.uk testimonials look good and I just need to get over to Barnsley - which is in Yorkshire Sad Geoff
Post #325224 30th Apr 2015 11:41pm
miggit
Just noticed that some bright spark has come up with a locking wheel nut removal kit, I very much doubt that you will be able to get hold of one Sad , BUT, they claim that the RAC and the AA both use them Very Happy and they do an adapter for Range Rover wheel nuts too Very Happy
Might be worth a call, could save you a lot of bother, and if your a member (and you'd be mental to have a ffrr with out breakdown cover Wink ) could save you some dosh Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #325226 30th Apr 2015 11:46pm
miggit
Craig, sneeky, am I correct in assuming that the top spins, would have to lock it up and then drill with a cobalt or boron drill bit, OK I accept that they are not a 2 minute job Thumbs Up
but look, behold the removal kit, with Range Rover adapter
http://www.dynomec.co.uk/locking-wheelnut-remover.html Yesterday I couldn't spell Engineer... Today I are one!
Post #325228 30th Apr 2015 11:52pm
Good shout i reakon Geoff Thumbs Up
Post #325229 30th Apr 2015 11:53pm
Page 1 of 3 123>
