![]() | Home > Technical (L322) > Fault code P0480 |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35526 ![]() ![]() |
its a generic code for a relay failure...have a read here,
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 141 ![]() ![]() ![]() |
Oh ok I get you any chance of where my might find this relay Stan?? |
not sure but you can download the WM and seek out this info.. |
I've downloaded the wm I've had a read and it's saying that the cooling fan operates off the ecm is that right??
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8405 ![]() ![]() ![]() |
As Stan says that is a generic fault code to indicate something is wrong with the system, it does run from the engine ECU but the fault probably lies in one of the temp sensors, there is one in the thermostat housing and one in the bottom hose... you could try Maxi fuse 61 which is a 50amp, if not it's going to take a bit of testing of the circuit to find the problem... Pete
Zirconblue Member Since: 16 Apr 2015 Location: Kent Posts: 1277 ![]() ![]() ![]() |
After the fuse the first test to make is to unplug the fan and see if it's getting 12v, if it is then you know the fan motor is kaput. |
The fan has three wires, one 12v, one earth and a control wire from the Engine ECU..... If it's got 12v it could be the fan or the ECU or HEVAC control module or either of the temp sensors... all these have to work to tell he ECU to turn the fan on.... Pete
Agreed, although if the multi meter shows 12v, an earth and presumably either 5v or 12v on the remaining wire it still shows it as the fan being at fault. It also disproves a broken wire leading to the fan.
To be able to test power to the trigger wire you will have to ensure that the ECU is calling for the fan to come on, this happens when the engine temp gets very hot, above 110deg C, when the engine driven fan can't cope, it is difficult to get it to come on whilst stationary as the engine fan works so well... when it does come on the voltage at the trigger wire will vary to control the fan speed..... Pete
I know with my Sykes-Pickavant code reader i can manually tell the ECU to run the cooling fan (and other actuators), for doing just such a test.
Hi I've test for power I get permanent live to be wire then nothing on the others. When I put my solus ultra on it I can enable it it to run fast medium or slow..so it was wont work on its own. I have heard that it should work when the air con it put on but still doesn't?? |
It only comes on if the aircon asks for it when it gets hot, can't say I've ever noticed it come on so it doesn't work much....
Bearing in mind these things are designed to operated everywhere from Scandinavia in winter to the Mohave in summer, it's likely the fan doesn't operate much when it comes to running the AC in the UK.
The ECM controls the speed of the fan, it comes on for the air con and also if the engine fan can't cope.... Pete
