![]() | Home > In Car Electronics (L322) > 2012 FFR Display & Instruments and Sound questions |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 ![]() ![]() ![]() |
1.) main instrument cluster - the space between the two dials seems to be only used for the menu controlled by the top right multifunction button.
Ensure you have tuned the TMC to an active European TMC station (in the UK it tends to be Classic FM). Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
many thanks so far both - will check subwoofer and TMC is on.How does it show traffic over at your end?
No updates available yet sir and am unsure if anyone is working on one |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35474 ![]() ![]() |
on the 2006-2009 years there is a small TMC logo on the top left of the screen , i should think yours is the same...
Hi, well, I do have the logo and its recieveing data, but I am "used" to the nav apps on the Iphone,
Closed roads are marked in black with a white circle each end of the problem. Issues are reported when you are using the navigation functions, you can check ahead if not using the menus. Your vehicle will recalculate routes if it is aware of problems and alert you. Land Rover Addict
Hi all, I need to come back on this again.
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 ![]() ![]() |
Hi Heppsen,
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 ![]() ![]() ![]() |
Hi Heppsen
As i said above... Even the LR handbook shows sat nav in the middle display but they never finished the software! Useless! |
Well, thanks again gents, but thats utterly dissapointing, not to call it "bullshitting" customers.
It would be great if you get it to work Heppsen and although it is only bits and bytes, there are a lot of manhours involved in developing and testing this stuff even for such a seemingly small change. The investment for GAP would be quite high.
Well, I would support this, but can't see a big problem actually.
