Home > In Car Electronics (L322) > 2012 FFR Display & Instruments and Sound questions
heppsen
Germany 2012 Range Rover Vogue TDV8 Santorini Black
Hi folks,
I wonder if some of you can shed some light on some things I ask myself since owning the 7/12 TDV8 for a week or two now.
1.) main instrument cluster - the space between the two dials seems to be only used for the menu controlled by the top right multifunction button.
Its mainly black during a normal drive, even with the NAV system switched on.
Why does the NAV system does not use this space while driving to assist with lane change and turn right/left instructions plus a small graphic?
Am I missing something here or is this the way it shall be?
2.) I do have the 1200 Watt Logic 7 HD system and I am somewhat disappointed from the outcome of music. I tried all sources now, radio, CD, Ipod and USB Stick and I can't for the best try get a decent bass line from it.
While typing and thinking now, maybe the subwoofer is inactive either by a blow fuse or made inactive by removal of said fuse. Question: is the subwoofer an active system with a seperate fuse? need go and check this.
3.) Does the NAV System show traffic jams and slow moving traffic by some means? There are some red and yellowish arrows in the 3D screen if you use multiframe viewpoint (traditional viw left and 3D view right of scree)
4.) I had a NAV update done by the dealers and the nav material is from may 2014 - is this the latest one?
regards and thanks for help
heppsen
Post #321728 8th Apr 2015 7:04am
No sir, that is how the dash was made! Disappointing as they never finished writing the software to have the NAV in the centre as they do in the L405! Rolling Eyes
Check the sub woofer has not broken into 2 halves! Find they de-laminate a lot Rolling Eyes
Does in the UK so don't see why it should not in Germany Neutral
Post #321735 8th Apr 2015 7:53am
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Ensure you have tuned the TMC to an active European TMC station (in the UK it tends to be Classic FM). Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #321737 8th Apr 2015 8:04am
heppsen
many thanks so far both - will check subwoofer and TMC is on.How does it show traffic over at your end?
I like the comment about the unfinalised software.... Mr. Green
Can we get an update here?
regards
heppsen 2017 MB V-Class
2016 Q7 (gone)
2012 FFRR TDV8
2012 Smart Pulse Turbo
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #321746 8th Apr 2015 8:24am
No updates available yet sir and am unsure if anyone is working on one Rolling Eyes
The Traffic warning both messages on the screen Re-route's you and audio warns you. Thumbs Up
Post #321747 8th Apr 2015 8:27am
on the 2006-2009 years there is a small TMC logo on the top left of the screen , i should think yours is the same...
if the logo has a red line through it then its not receiving data ... ... - .- -.
Post #321749 8th Apr 2015 9:19am
heppsen
Hi, well, I do have the logo and its recieveing data, but I am "used" to the nav apps on the Iphone,
showing green roads for free traffic, yellow(ish) for slow traffic, ornage for stop n go and red into dark red-black(ish) for standstill.
This is convenient for the morning commute and it works almost exact to the meter.
I just wondered if the high-tech Nav system would have something similar or maybe an update available. I understood the whole thing is from Becker, so shoul dbe possible to get an up to date service from this system?
I would have loved to have some sort of mark on the road ahead in graph display telling me there is a bloackeg or slow traffic etc.
Maybe I am expecting to much as its still a Range Rover... Rolling with laughter
I am slightly disappointed with the main centre TFT as it does not make use of the space between the dials.
Thats absolutely "stunning".
thanks so far,
regards
2016 Q7 (gone)
2012 FFRR TDV8
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #321767 8th Apr 2015 12:41pm
DMRR
Closed roads are marked in black with a white circle each end of the problem. Issues are reported when you are using the navigation functions, you can check ahead if not using the menus. Your vehicle will recalculate routes if it is aware of problems and alert you. Land Rover Addict
Previous
XXXXXXXXXXXXXXXX
2004 4.4V8 Vogue
Post #321776 8th Apr 2015 1:03pm
heppsen
Hi all, I need to come back on this again.
I had a nosey around the internet over the weekend and found some pictures and a movie,,
clearly showing "music information" between the two dials on a 2010 Range Rover L322.
See pics below.
And in this Video you can see it in abt 20 seconds into the film as well
So, questions:
1. Can I have this as well in my 2012?
2. why don't they make it "selectable"?
3. if you have your satnav running, you can't even see what source of music you choose with the mode button ion the steering wheel....
Am I missing something here?
Can't believe a 100+k€ vehicle from 2012 has such alarming comfort mishaps?
I sort of accepted that it does not show the nav arrows in the main display upfront.
regards
2016 Q7 (gone)
2012 FFRR TDV8
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #322414 13th Apr 2015 11:17am
Andy B
Hi Heppsen,
Some more info on the MP3 display (or lack of it) here :-
http://www.fullfatrr.com/forum/topic26097.html
Very disappointing!
Cheers,
Andy SDV8 AB MY 2019
SDV8 VSE MY 2015 - Gone
5.0 S/C AB MY 2010 - Gone
4.2 S/C VSE MY 2006 - Gone
Post #322417 13th Apr 2015 11:38am
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Hi Heppsen
I also raised this query - dead end I'm afraid.
http://www.fullfatrr.com/forum/topic28988.html 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #322444 13th Apr 2015 4:41pm
As i said above... Even the LR handbook shows sat nav in the middle display but they never finished the software! Useless! Rolling Eyes
Post #322475 13th Apr 2015 8:10pm
heppsen
Well, thanks again gents, but thats utterly dissapointing, not to call it "bullshitting" customers.
I can't see a reason why they should not be able to provide a proper update on this, even more so as the hardware seems to be more or less the same as in the later models.
They even had two years from 2010 until mid 2012 where they still produced the L322 and did not come up with a solution as promised in video, brochures and owners manual?
You actually wonder why all those first customers did not jump the necks of the people involved - dealers, Landrover reps, whoever..... funny ain't it?
I will try my best and check my connections into LR germany - won't be of much help I guess, but maybe its worth a try at least.
Even microsoft provides after sales serveice for old software roughly a decade after selling it stopped, so Landrover should be able to serve long standing customers with 3 year old products.
What a misery..... and what a missec chance.
I really wonder if the GAP people know of this?
Need to check. Its only bis and bytes after all. Not rocket science.
regards
2016 Q7 (gone)
2012 FFRR TDV8
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #322537 14th Apr 2015 9:15am
ebajema
It would be great if you get it to work Heppsen and although it is only bits and bytes, there are a lot of manhours involved in developing and testing this stuff even for such a seemingly small change. The investment for GAP would be quite high.
Maybe they should start a Kickstarter or Indiegogo campaign for these sort of mods and if enough of us L322 fans get into it, they can get it to work maybe and not loose their shirt Wink. MY 2010 5.0 SC Galway green and sand interior!!
Post #322559 14th Apr 2015 11:41am
heppsen
Well, I would support this, but can't see a big problem actually.
after all its all there anyway:
the dials are meant to move if needed, so this is already programmed (part of 4wd system showing in the middel if selected)
the nav system does have a part screen showing the next exit and way to go - so should be easy to be used (read: send) to be displayed on another screen (read: main display)
the audio system also des show what it plays on the middel screen, so again, it could be easy to show this information on the main display (and it must have been programmed actually as its been photographed before launch of the 2010 model)
so basically the computer is there, the info is there and the screens are there..... whats the point in not making use of a combination of these?
Hard to accept that this should not be a solvable problem - only question is: who to ask?
regards
2016 Q7 (gone)
2012 FFRR TDV8
1986 MB W126
1965 LR Series 2A
1961 LR Series 2
Post #322584 14th Apr 2015 2:21pm
