Home > In Car Electronics (L322) > 2012 FFR Display & Instruments and Sound questions |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16306 |
1.) main instrument cluster - the space between the two dials seems to be only used for the menu controlled by the top right multifunction button.
8th Apr 2015 7:53am |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
Ensure you have tuned the TMC to an active European TMC station (in the UK it tends to be Classic FM). Land Rover Addict XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
8th Apr 2015 8:04am |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 |
many thanks so far both - will check subwoofer and TMC is on.How does it show traffic over at your end?
8th Apr 2015 8:24am |
No updates available yet sir and am unsure if anyone is working on one
8th Apr 2015 8:27am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35474 |
on the 2006-2009 years there is a small TMC logo on the top left of the screen , i should think yours is the same...
8th Apr 2015 9:19am |
Hi, well, I do have the logo and its recieveing data, but I am "used" to the nav apps on the Iphone,
8th Apr 2015 12:41pm |
Closed roads are marked in black with a white circle each end of the problem. Issues are reported when you are using the navigation functions, you can check ahead if not using the menus. Your vehicle will recalculate routes if it is aware of problems and alert you. Land Rover Addict
8th Apr 2015 1:03pm |
Hi all, I need to come back on this again.
13th Apr 2015 11:17am |
Andy B Member Since: 03 Apr 2012 Location: West Malling Posts: 1223 |
Hi Heppsen,
13th Apr 2015 11:38am |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1661 |
Hi Heppsen
13th Apr 2015 4:41pm |
As i said above... Even the LR handbook shows sat nav in the middle display but they never finished the software! Useless! |
13th Apr 2015 8:10pm |
Well, thanks again gents, but thats utterly dissapointing, not to call it "bullshitting" customers.
14th Apr 2015 9:15am |
It would be great if you get it to work Heppsen and although it is only bits and bytes, there are a lot of manhours involved in developing and testing this stuff even for such a seemingly small change. The investment for GAP would be quite high.
14th Apr 2015 11:41am |
Well, I would support this, but can't see a big problem actually.
14th Apr 2015 2:21pm |
