Home > In Car Electronics (L322) > Bluetooth retrofit |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7801 |
No problem. Let us know how you get on. 2011 Range Rover Vogue SE 4.4 TDV8
6th Apr 2015 1:19pm |
The wiring should all be there, just connect microphone to connector that's behind the overhead console near the interior light, don't do anything in the boot, 2011 Range Rover Vogue SE 4.4 TDV8
7th Apr 2015 1:19pm |
AKIS Member Since: 23 Apr 2009 Location: GREECE Posts: 186 |
Thanks and noted |
7th Apr 2015 3:46pm |
mjdronfield hi again.Ready to proceed with installation but need a clarification.
23rd Apr 2015 2:03pm |
I have this connection for the antenna. It should be there in the car already
23rd Apr 2015 4:36pm |
so the black purple connector in ulf and the remaining white one in antenna.White connector i am speaking for as in attached photo
24th Apr 2015 8:07am |
just to be more accurate white connector in red rectangular.
24th Apr 2015 8:14am |
Hi,
24th Apr 2015 5:01pm |
Once again many thanks for your help |
24th Apr 2015 7:38pm |
Hi.Back again.I have just installed ulf after having re pinned 54 pin connector exactly as per chart in this threat.
19th May 2015 6:38pm |
You have fitted the microphone into the space opposite the sunroof switch ?
19th May 2015 7:26pm |
Good day.Yes microphone fitted.Can it be a defective microphone or any connections problem?I have touched nothing else other than rewiring the 54 pin connector exactly as per chart.
20th May 2015 7:23am |
I believe there are only 3 wires for the microphone, and 2 of them can be the other way round and it still works....
20th May 2015 4:22pm |
These are from the original wiring diagram in RAVE, so will be the OLD PIN numbers, but you can see the wiring setup....
20th May 2015 4:33pm |
