Home > Technical (L322) > coolant use
NoProDeluxe
2004 Range Rover Vogue 4.4 V8 Stornoway Grey
coolant use
I have had my Range Ro ver vogue for a couple of months now and have put in .75 of a lte of coolant. I can't see any leaks anywhere. Is his normal coolant use?
G
Post #28431 19th Sep 2010 8:52am
darrenmax
Belgium 2003 Range Rover Vogue Td6 Giverny Green
they dont normally use coolant, keep an eye on it, it could be a cracked cylinder leaking into the combustion area or into the oil, check the oil for white sludge , or maybe you have overfilled it , the floating dipstick has a small ball on it with the fill level when cold 2002 td6 vogue, 06 supercharged facelift
Post #28445 19th Sep 2010 12:22pm
dan_uk_1984
Do you have any tell tale white crust anywhere around the header tank? Mine used to use about 1/4 a L every month or so. Then out of nowhere my header tank split in half. It's never used a drop since.
Dan
Post #28450 19th Sep 2010 1:59pm
I have had to top up with about 1/4 pint once a month, no sign of leaks or problems, guess its going somewhere so will probably have to wait til it blows! Big Cry .
Post #28455 19th Sep 2010 2:34pm
NoProDeluxe
No white crust, the oil is clean, no frothy stuff. Car runs like a dream and is getting a steady 20mpg. I'll just watch.
Thanks Guys
G
Post #28483 19th Sep 2010 6:38pm
andyw
England 2002 Range Rover HSE 4.4 V8 Zermatt Silver
i had that last year, in the summer it was loosing coolant as you are and had no tell tale, as winter came a small amount of steam would apear, then it got worse and it would look like it was on fire (steam) turned out to be four ribs on the radiator
new radiator in feb this year and not a drop of coolant gone since Thumbs Up 02 Range Rover HSE Zambezie silver 4.4
Post #28508 19th Sep 2010 8:32pm
NoProDeluxe
Had the old bird MOTed today and they pressure tested the cooling system to 2 bar and no leeks!
G
Post #28767 21st Sep 2010 7:25pm
Jem0911
United Kingdom 2015 Range Rover Vogue SE SDV8 Corris Grey
My 4.4 has been weeing for weeks. Booked it into Nene Overland last week.
Slowly but surely using less coolant everyday until today when it took none.
Nene pressure tested No Leaks!!!!!!!!!!!
Talk me through that.
Will probably start again tomorrow. 15MY SDV8 Vogue SE
Post #29768 28th Sep 2010 9:54pm
Jem0911
The morning after I had the car back from Nene it leaks as usual using 200/500ml daily.
Please some-one help me.
Again today had the gas side checked, no leaks.
No Sludge,
No white guff.
18.9 MPG
What else could it be? 15MY SDV8 Vogue SE
Post #31018 6th Oct 2010 3:22pm
. Sheep ... - .- -.
Post #31019 6th Oct 2010 3:24pm
delamo
England 2007 Range Rover Vogue SE TDV8 Tonga Green
Only a guess Jem0911 Question
Was the pressure test (which found no leaks) conducted via the coolant header tank? - maybe the seal with the pressure tester was a better seal than the header tank cap - which might be leaking/steaming when at full temperature.
Like I said - its only a guess Neutral
Post #31055 6th Oct 2010 6:36pm
Jem0911
Thank you for the post might well be case.
Before the visit to Nene I could see a small
puddle on the drive?
Radweld my only option now as three garages have tried to find a leak. 15MY SDV8 Vogue SE
Post #31067 6th Oct 2010 6:59pm
DeltaC
United Kingdom 2003 Range Rover Vogue 4.4 V8 Buckingham Blue
Do not put Radweld in.... really, not in that motor. They have enough of an issue trying to cool the gearbox without adding an additional hose / fin blocking agent.
Consider doing the following but only if you are Mechanically Confident.Take the lower plastic cover off from below the engine.
Remove the viscous fan and cowling. (10 mins).
Start the car and bring it up towards running temp. Watch the temp like a hawk and do not let it overheat. (Bear in mind you have removed the viscous fan so it will if you let it).
I had a pinhole in the radiator of a LSE and for the life of me, couldn't find it. It does not help that the windmill that is attached to the front of the engine disipates any leaking fluid rapidly.
By removing the fan and cowling you have significantly improved visibility aroundthe full radiator, water pump and miriad of hoses so pinholes will be easier to spot.
Post #31085 6th Oct 2010 8:26pm
delsilencio
France 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
easiest way, pressure check !
Go to any workshop and let set the cooling system under pressure. It will sputter somewhere!
Maybe itīs a bad hose connection, maybe its the rad, maybe itīs the expansion tank ..
The quickest, easiest, cheapest and savest way is a pressure check... XJC, RRV8, Series1 86 and 107% of real pleasure
Post #31207 8th Oct 2010 9:06am
SGW
United Kingdom 2009 Range Rover Autobiography 5.0 SC V8 Stornoway Grey
I have had this happen, check the radiator near the top right hand corner (if sitting in the drivers seat). This has happened to 3 radiators. What happens is the leak is so small it evaporates before it drips on the floor, you can usually smell the burning antifreeze.
Stewart.
Post #31294 9th Oct 2010 9:56pm
