![]() | Home > Technical (L322) > coolant use |
darrenmax Member Since: 20 Apr 2010 Location: antwerp Posts: 420 ![]() ![]() ![]() |
they dont normally use coolant, keep an eye on it, it could be a cracked cylinder leaking into the combustion area or into the oil, check the oil for white sludge , or maybe you have overfilled it , the floating dipstick has a small ball on it with the fill level when cold 2002 td6 vogue, 06 supercharged facelift
Do you have any tell tale white crust anywhere around the header tank? Mine used to use about 1/4 a L every month or so. Then out of nowhere my header tank split in half. It's never used a drop since.
I have had to top up with about 1/4 pint once a month, no sign of leaks or problems, guess its going somewhere so will probably have to wait til it blows! |
NoProDeluxe Member Since: 11 Jul 2010 Location: uk Posts: 24 ![]() ![]() |
No white crust, the oil is clean, no frothy stuff. Car runs like a dream and is getting a steady 20mpg. I'll just watch.
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 ![]() ![]() ![]() |
i had that last year, in the summer it was loosing coolant as you are and had no tell tale, as winter came a small amount of steam would apear, then it got worse and it would look like it was on fire (steam) turned out to be four ribs on the radiator
Had the old bird MOTed today and they pressure tested the cooling system to 2 bar and no leeks!
Jem0911 Member Since: 07 Jan 2010 Location: East Northants Posts: 357 ![]() ![]() ![]() |
My 4.4 has been weeing for weeks. Booked it into Nene Overland last week.
The morning after I had the car back from Nene it leaks as usual using 200/500ml daily.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35542 ![]() ![]() |
delamo Member Since: 17 Mar 2010 Location: Beaconsfield, Bucks Posts: 1121 ![]() ![]() ![]() |
Only a guess Jem0911 ![]() Was the pressure test (which found no leaks) conducted via the coolant header tank? - maybe the seal with the pressure tester was a better seal than the header tank cap - which might be leaking/steaming when at full temperature. Like I said - its only a guess ![]() |
Thank you for the post might well be case.
DeltaC Member Since: 22 Mar 2010 Location: Aberdeenshire Posts: 148 ![]() ![]() ![]() |
Do not put Radweld in.... really, not in that motor. They have enough of an issue trying to cool the gearbox without adding an additional hose / fin blocking agent.
delsilencio Member Since: 08 Apr 2009 Location: toulouse Posts: 116 ![]() ![]() ![]() |
easiest way, pressure check !
SGW Member Since: 09 Sep 2009 Location: Headcorn Kent UK Posts: 77 ![]() ![]() ![]() |
I have had this happen, check the radiator near the top right hand corner (if sitting in the drivers seat). This has happened to 3 radiators. What happens is the leak is so small it evaporates before it drips on the floor, you can usually smell the burning antifreeze.
