Home > Maintenance & Mods (L322) > Westfailia Tow Bar
steve9bug
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Westfailia Tow Bar
A mate of mine witH another body shop has just asked if i want a tow bar armature and detachable hitch with key and case. but no electrics. £100 YES PLEASE LOL.
Just need electrics now and decide if i will fit it or just get it fitted by auto tow.
How long and hard are they to fit guys, COULD I FIT IT AND DO ELECTRICS LATER OR WOULD THAT JUST BE MORE WORK.
Looked in WIKI But no images on now
Post #318840 20th Mar 2015 2:40pm
its on topix,
http://topix.landrover.jlrext.com/topix/co...oupId=1671 ... - .- -.
Post #318841 20th Mar 2015 2:48pm
Fish
United Kingdom 2007 Range Rover Vogue TDV8 Rimini Red
I have just replaced the electrics on mine to change from 7 pin to 13 pin following a problem. It's plug and play but took me a bit longer than the quoted 10 mins as you have to remove the trims in the boot to unclip the existing wiring loom which plugs into the right hand side. The hardest part was getting the grommet in the hole in the bodywork but it is a relatively easy job and the good thing about the RR is all the panels come off easily.
Post #318842 20th Mar 2015 2:58pm
steve9bug
At £320 plus vat to fit and supply single electrics I think I will be fitting it myself once I get the electrics to go with it
Post #318860 20th Mar 2015 6:21pm
n1cktdv8
£320 Shocked
I have a dedicated LR loom for 13 pin and it wasn't that much fitted? Is this where I put the car details and a bit about myself ?........
Post #318861 20th Mar 2015 6:22pm
steve9bug
I will try and find a seven pin setup if I can and just fit it one Saturday when the garage is quiet
Post #318863 20th Mar 2015 6:25pm
Prepros123
England 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
I fitted the armature on mine last weekend. Quite a straightforward job though a fair bit to remove. Worse part I found was gently uncoiling the bumper at the sides. Electrics were easy to do just plug in to existing plugs. If you need any advice feel free to ask whilst fresh in my mind Thumbs Up
Post #318872 20th Mar 2015 7:15pm
steve9bug
Thumbs Up just need to find the electrics first mate
Post #318873 20th Mar 2015 7:17pm
Welshdragon
Have a look at pf Jones, I got the 13 pin electrics with 7 pin adapter, plug and play. If it dont work.......burn it!
Post #318875 20th Mar 2015 7:32pm
Prepros123
I got mine from Jon Daunter works fine
Post #318877 20th Mar 2015 7:36pm
