Home > Maintenance & Mods (L322) > Westfailia Tow Bar |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35476 |
its on topix,
20th Mar 2015 1:48pm |
Fish Member Since: 30 Aug 2014 Location: Bolton Posts: 301 |
I have just replaced the electrics on mine to change from 7 pin to 13 pin following a problem. It's plug and play but took me a bit longer than the quoted 10 mins as you have to remove the trims in the boot to unclip the existing wiring loom which plugs into the right hand side. The hardest part was getting the grommet in the hole in the bodywork but it is a relatively easy job and the good thing about the RR is all the panels come off easily. |
20th Mar 2015 1:58pm |
steve9bug Member Since: 25 Aug 2013 Location: sunderland Posts: 356 |
At £320 plus vat to fit and supply single electrics I think I will be fitting it myself once I get the electrics to go with it |
20th Mar 2015 5:21pm |
n1cktdv8 Member Since: 19 Aug 2013 Location: Cheshire Posts: 1754 |
£320
20th Mar 2015 5:22pm |
I will try and find a seven pin setup if I can and just fit it one Saturday when the garage is quiet |
20th Mar 2015 5:25pm |
Prepros123 Member Since: 28 Sep 2014 Location: Cornwall Posts: 35 |
I fitted the armature on mine last weekend. Quite a straightforward job though a fair bit to remove. Worse part I found was gently uncoiling the bumper at the sides. Electrics were easy to do just plug in to existing plugs. If you need any advice feel free to ask whilst fresh in my mind |
20th Mar 2015 6:15pm |
just need to find the electrics first mate |
20th Mar 2015 6:17pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
Have a look at pf Jones, I got the 13 pin electrics with 7 pin adapter, plug and play. If it dont work.......burn it!
20th Mar 2015 6:32pm |
I got mine from Jon Daunter works fine |
20th Mar 2015 6:36pm |
