Home > In Car Electronics (L405) > DashCams
KeithG934
DashCams
Has anyone successfully hard wired an ignition controlled DashCam into the overhead console on a L405. If so - how? Rolling Eyes
Post #318679 19th Mar 2015 4:57pm
Dickie
I use the central cigarette lighter socket and have routed the cabling under the passenger seat, up the B pillar to the headlining then to the windscreen. You can just notice the wire out the side of the central hatch but I can bear with that.
I coped with it that was also because my Blackviiew has been originally in my L405, then in my ATB Sport, now in my Supercharged Sport and will get moved to my SVR next month. Hard wiring each time would have been too much of a PITA for me.
Post #318719 19th Mar 2015 9:54pm
scanner
United Kingdom 2010 Range Rover Vogue TDV8 Zermatt Silver
Re: DashCams
Did you get anywhere with that Keith? 2010 TDV8 Zermat Silver with dirty streaks
2013 L405 3L Vogue SE Corris grey
Post #319394 24th Mar 2015 12:03pm
Emperor Mong
This new K1S reviewed by techmoan looks good.
I'm thinking about getting one wired in.
Anyone know a good installer?
Post #319404 24th Mar 2015 12:51pm
^ nice dashcam that, but its much cheaper to get two separate ones.. ... - .- -.
Post #319407 24th Mar 2015 1:26pm
Emperor Mong
I rather like the tiny size and a single (potentially hidden) location for the recording device. More difficult to nick and neater.
Post #319414 24th Mar 2015 3:14pm
thats a definete plus having a small camera......my front 0801 is pretty inconspicuous.... ... - .- -.
Post #319416 24th Mar 2015 3:24pm
I fitted my Blackvue at the weekend - used the same method that I used for my L322 - only it was easier on the L405 Thumbs Up - cable tucks nicely into the headlining along to the passenger side, then tucks behind the join at the top of the door and slips behind the black door seal.
Lower the glovebox so that you can see the fuse box. From there, you can push off the dash end panel - it's only clipped in - the cable can then run into the fuse box area and push the end panel back on.
I used a piggyback fuse holder into a fuse that was switched live.
The ground connection was a little more fiddly - I ended up with a crocodile clip onto the metal area as there was nowhere obvious to bolt a connection to.
Took under ½ hour and a good chunk of that was spent deciding where to mount the camera itself - I eventually went for high on the passenger side, just to the left of the blacked area - not a perfectly symmetrical image, but a much neater install than down lower but centered.
Post #326084 5th May 2015 1:09pm
is that connected to a permanent or ignition live Alistair? ... - .- -.
Post #326091 5th May 2015 1:29pm
Whistle
Instructuions for the camera say permanent live & it records if someone bumps you whilst parked, but given the RR record with battery life, I've always wired mine to switched ignition live Thumbs Up
Post #326093 5th May 2015 1:34pm
Thumbs Up ....that was my concern as well when i did mine so i to put it on an ignition live .. ... - .- -.
Post #326094 5th May 2015 1:37pm
Welshdragon
0801 and the more recent 0806 are very good dash cams for the price, my 0801, after updating the firmware when fitted has never given trouble since.
I know its not a 405 but fitting is in the wiki for the front and rear camera's hard wired to ignition live Thumbs Up If it dont work.......burn it!
Post #326116 5th May 2015 2:22pm
cripboy
Scotland 2015 Range Rover Vogue SE SDV8 Corris Grey
any pictures of your install?
Keith Regards
Keith
Post #327345 12th May 2015 9:47am
They're on my camera - I've been meaning to post them - will hopefully get round to it this evening
Post #327347 12th May 2015 9:48am
cripboy
that would be good
Keith Regards
Keith
Post #327348 12th May 2015 9:49am
