Home > In Car Electronics (L405) > DashCams |
Dickie Member Since: 14 Nov 2012 Location: Gloucestershire Posts: 71 |
I use the central cigarette lighter socket and have routed the cabling under the passenger seat, up the B pillar to the headlining then to the windscreen. You can just notice the wire out the side of the central hatch but I can bear with that.
19th Mar 2015 8:54pm |
scanner Member Since: 14 Jul 2010 Location: Yorkshire Posts: 61 |
Did you get anywhere with that Keith? 2010 TDV8 Zermat Silver with dirty streaks 2013 L405 3L Vogue SE Corris grey |
24th Mar 2015 11:03am |
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 |
This new K1S reviewed by techmoan looks good.
24th Mar 2015 11:51am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35266 |
^ nice dashcam that, but its much cheaper to get two separate ones.. ... - .- -.
24th Mar 2015 12:26pm |
I rather like the tiny size and a single (potentially hidden) location for the recording device. More difficult to nick and neater. |
24th Mar 2015 2:14pm |
thats a definete plus having a small camera......my front 0801 is pretty inconspicuous.... ... - .- -.
24th Mar 2015 2:24pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
I fitted my Blackvue at the weekend - used the same method that I used for my L322 - only it was easier on the L405 - cable tucks nicely into the headlining along to the passenger side, then tucks behind the join at the top of the door and slips behind the black door seal.
5th May 2015 12:09pm |
is that connected to a permanent or ignition live Alistair? ... - .- -.
5th May 2015 12:29pm |
Instructuions for the camera say permanent live & it records if someone bumps you whilst parked, but given the RR record with battery life, I've always wired mine to switched ignition live |
5th May 2015 12:34pm |
....that was my concern as well when i did mine so i to put it on an ignition live .. ... - .- -.
5th May 2015 12:37pm |
Welshdragon Member Since: 20 Jan 2012 Location: here and there...but not where I should be Posts: 1899 |
0801 and the more recent 0806 are very good dash cams for the price, my 0801, after updating the firmware when fitted has never given trouble since.
5th May 2015 1:22pm |
cripboy Member Since: 10 May 2015 Location: Edinburgh Posts: 12 |
12th May 2015 8:47am |
They're on my camera - I've been meaning to post them - will hopefully get round to it this evening |
12th May 2015 8:48am |
12th May 2015 8:49am |
