Home > Wheels & Tyres > TPM system.........again
Page 2 of 3 <123>
@birdbrian,
the spare tpms is monitored by the tpms module,
Post #317836 13th Mar 2015 12:56pm
Birdbrain
United Kingdom 2014 Range Rover Vogue SE SDV8 Santorini Black
Cheers Stan
So if I get a new sensor fitted to the spare wheel the module should pick it up without having to fit it and drive with it on for a few miles?
Post #317839 13th Mar 2015 1:11pm
no, you will have to fit on FF and drive for at least 15 minutes......saying that , LR diagnostics can re-programme the sensor while its in the spare, but that will cost.. ... - .- -.
Post #317841 13th Mar 2015 1:19pm
Birdbrain
Cheers Stan.
I'll see if my local independent can programme it.
Post #317852 13th Mar 2015 1:43pm
Birdbrain
We seemed to have solved the problem. Local indie found spare wheel sensor and / or aerial giving error. From Stans post and other research I'd done I dediced it could be the TPM module in the boot as that also acts as the aerial for the boot. We fitted a borrowed module and problem went away. Now nearly £100 lighter after buying a new one. Fingers crossed........
Post #317878 13th Mar 2015 4:06pm
Andy_J wrote:
Will only fail an MOT on a post 2012 car. The working TPMS requirement was not retrospective
Are you sure ?
I agree that TPMS isn't a requirement on a pre-2012 car.
However, I thought if it was fitted, then it has to work - any warning lights are an MOT fail for all cars.
Post #317926 13th Mar 2015 8:58pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Think it is because it is not a testable item, so can't failed
From the manual - specifically excludes it from the test
The inspection of the tyre pressure monitoring
system (TPMS) only applies to passenger vehicles
with:
• four or more wheels, and
• not more than 8 passenger seats excluding the
driver’s seat, and
• first used on or after 1 January 2012 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #317965 13th Mar 2015 11:09pm
I thought that any options fitted had to work - including towing sockets and the like.
Quote:
Warning lights
As well as electronic parking brake and electronic stability control warning lights (where fitted) the MOT test will also include checks for the correct function of the following, where fitted;
Headlight main beam warning light
Electronic power steering warning light
Brake fluid level warning light
Tyre pressure monitoring system warning light
Airbag warning light
Seat belt pre-tensioner warning light
Steering & suspension
That's what I was told by my MOT tester - but he could have been wrong.....
Post #317973 14th Mar 2015 1:06am
sleepezy
Sorry I didn't get back to you on the location Birdbrain but see Stan's got there now - all done by the garage anyway so I don't know!
My car (07) has passed 2 MOT's now with this error.
Post #317982 14th Mar 2015 9:28am
I seriously wouldn't fork out any more money on new valves.
Best investment would be an IIDTool to turn the system off. It's hopeless! IMO of course Idea Got - 2017 SDV8 Autobiography in Loire Blue
Post #317986 14th Mar 2015 10:53am
elmer
2008 Range Rover Vogue TDV8 Java Black
Alistair wrote:
I had a similar intermittent problem for ages - good money after bad - replaced all the valves then a couple of the sensors and it was still happening.
I bought an IID tool, switched the bloody thing off & had the valves removed from the wheels - I've never regretted it Thumbs Up
What iidtool did you bougth?could you cancel the tpms warnings?
Thany you
Post #325887 3rd May 2015 11:07pm
I had the bluetooth one, but I think they can all disable the TMPS
http://www.gap-diagnostic.com/products/iidtool.html
For pricing, try Dan @ Duckworths Thumbs Up
I disabled TPMS, then had the valves removed from the wheels. The valves are so weak, I consider them dangerous - I had one break off as I was checking a tyre pressure.
Post #325892 3rd May 2015 11:31pm
miggit
I fitted a TPMS system to my ffrr, I'm really happy with it Shocked , but it's not a L/R product Wink Mine has a display that constantly shows the Tyre pressure and the temperature, and goes nuts and starts flashing and bleeping if the pressures drop or the tyre gets too hot (getting ready to go pop Shocked). It does have the in wheel monitors, as opposed to the cap type, which I was told can't handle pressures over 30 psi. So they would have been on good for me as the rears are run at 45 psi ( needs to be for towing very heavy trailers, that have large tanks with liquid slopping about in them ).
I can understand why your turning off your systems, telling you to check the pressures and NOT telling you which tyre is at fault, and by how much, is less than useless. It's like telling you the key is in the ignition and the doors open, like you wouldn't relies when you tried to lock the car Laughing
My system has gone off a couple of times recently, but this was due to a very cold night and the sun only hitting 1 side of the car, which caused 1 tyre to be 5 psi more than the other. I just press the silence button and watch the pressure climb as the tyre warms up when driving, takes a few miles to sort it's self out. But as it tells me what the problem is I can make the decision as to what to do. Yesterday I couldn't spell Engineer... Today I are one!
Post #326015 4th May 2015 9:40pm
elmer
Hello,I'm waiting for the final confirmation that I can cancel the TPMS warnings with the IID BT Tool number DA6412 (britpart) to buy in England and I send him to Spain.
Has anyone ever had this IIDTool and can anyone assure that I will be able do it?
Thank you
Elmer
Ahh , and sorry for my English
Post #326032 4th May 2015 11:59pm
YES Thumbs Up 2008 MY Supercharged
Post #326036 5th May 2015 1:46am
Page 2 of 3 <123>
