Home > Maintenance & Mods (L322) > Several faults, could all be due to pixel display?
cdocksey
2006 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
Hello, first inquiry...
2 days before buying a 2006 supercharged L322, the owner had flat battery due to internal lights left on.. He used another battery to jump start it and the pixel display lost the whole top part of the display. The whole top section where mileage appears. The bottom window area is ok. However the reverse camera does not show up on screen... Also, the passenger window won't go up with one touch. It will however go up keeping pressed the button (manual?) and it will go down with one touch... So motor works and switches too.
He says it's because he fried the display and that affects other things.... He's ordered a new pixel board but will take nearly 2 weeks to arrive.
Do you guys think this is the case of culd he have cried something else more costly or complicated?
Thanks for any input!!!
Post #317150 9th Mar 2015 7:05pm
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
Hi, welcome to the forum. I'll be surprised if the display is the cause of your faults. It's more likely that they are either down to him frying some of the electrics or because the battery is a dud. These cars can behave a little odd when the battery starts to die, with all sorts of electrical gremlins thrown up. I think the window can be reset so that the one touch works again. My Previous RR's!
2018 P400e Autobiography
2008 TDV8 Vogue
2006 TD6 Vogue
2007 TDV8 Vogue
2007 RRS (I know, it doesn't count!)
2005 4.4 Vogue on LPG
2005 TD6 Vogue
2003 4.4 Vogue
2001 4.6 HSE
2000 2.5 DHSE
1999 4.6 HSE
1997 4.6 HSE on LPG
1995 2.5 DSE
1989 3.9 EFI classic
1988 3.5 EFI classic
Post #317152 9th Mar 2015 7:23pm
check the battery and replace if necessary...info on how to fit the battery and set the steering parameters are in the wiki.. ... - .- -.
Post #317153 9th Mar 2015 7:28pm
cdocksey
Thanks for the input.. I have read that indeed ithy low voltage frm battery causes all sorts of problems but this happened after jump starting... I checked again the fault of the camera... Screen goes to camera mode when putting reverse and the text on the screen is there but the camera image is pure black.
I shall try to suggest to the owner your views.. Thanks again!
Post #317221 10th Mar 2015 2:26am
rej
England 2006 Range Rover Vogue 4.4 V8 Zambezi Silver
Black camera on mine meant the camera was not working, new camera and the standard grainy picture was restored. There is a difference between knowing your sh!t and knowing you're sh!t
2005 Registered 2006 MY 4.4 AJV8 Range Rover Vogue
Post #317246 10th Mar 2015 9:19am
I would start with a hard battery reset to see if the instrument cluster ecu is "in distress" then check if infact the battery on her is any good? As the instrument cluster pixels on the 06> model nearly NEVER fail!
The window probably just wants a reset (hold it in the up position for 10secs after closing)
Reverse cam is probably broken! 40% of 06my's i see are not working!
If your going to run such a complicated car in a country with a poor repair info structure, can i suggest an IID tool so you can do some minor diagnostics yourself sir Thumbs Up
Post #317273 10th Mar 2015 12:08pm
Vida
Good Nigth
Excuse me , how do you mean with hard battery reset?
Thanks in advance
regards
pd: I do not speak english Embarassed
Post #317621 12th Mar 2015 2:23am
" hard reset "
Turn car off and wait at least ten minutes for the car to go to sleep , disconnect the battery leads (- first ) and touch two cables together . This will remove an residual charge in the ECU's so when you reconnect the battery(- last ) it will be a complete re-start . 2008 MY Supercharged
Post #317622 12th Mar 2015 4:16am
As above Thumbs Up but for your information, even if you connect a diagnostic computer to your car with an ECU "in distress" there will be nothing you can do to reset it without a battery reset. So, that needs to be done first sir Thumbs Up
Post #317654 12th Mar 2015 9:19am
cdocksey
Thanks to all who have replied....
Sorry for my delay but was in the process of buying the car and driving it back home (yesterday..about 5 hours drive). Got a reduced power (limp home) by the way for the last hour. It must be the aux cooler pump of the SC. Just realized its in that vin range. Will check that tomorrow and do the hard reset tonight. Hope to leave the l322 battery-less overnight to dissipate current before shorting the cables (wouldn't like to blow anything).
Yes, Cam-Tech-Craig, all along my intention was to buy a faultmate to diagnose a lot myself. It's costly but very complete and being for my car alone, I don't mind that it is only for one Vin. I don't know if any "latest model scanner" has appeared in the last 4-6 months that may be better but otherwise the faultmate caught my eye. Hopefully I can get a well kept used one and just change the Vin at blackbox solutions.
The battery is new but it's a 900 amp maintenance free model, so it's not really up to par. Problem is that in this country there is nothing bigger. I'll have to see how I can get one over from the USA.
Shall keep you guys up to date as soon as I get do the reset...
Cheers!!
Post #317688 12th Mar 2015 1:47pm
Vida
Good afternoon.
Thank very much.
regards
Post #317862 13th Mar 2015 1:42pm
