Home > Maintenance & Mods (L322) > Several faults, could all be due to pixel display? |
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 863 |
Hi, welcome to the forum. I'll be surprised if the display is the cause of your faults. It's more likely that they are either down to him frying some of the electrics or because the battery is a dud. These cars can behave a little odd when the battery starts to die, with all sorts of electrical gremlins thrown up. I think the window can be reset so that the one touch works again. My Previous RR's!
9th Mar 2015 7:23pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
check the battery and replace if necessary...info on how to fit the battery and set the steering parameters are in the wiki.. ... - .- -.
9th Mar 2015 7:28pm |
cdocksey Member Since: 28 Sep 2014 Location: Caracas, Venezuela Posts: 15 |
Thanks for the input.. I have read that indeed ithy low voltage frm battery causes all sorts of problems but this happened after jump starting... I checked again the fault of the camera... Screen goes to camera mode when putting reverse and the text on the screen is there but the camera image is pure black.
10th Mar 2015 2:26am |
rej Member Since: 06 Jan 2014 Location: Stevenage Posts: 496 |
Black camera on mine meant the camera was not working, new camera and the standard grainy picture was restored. There is a difference between knowing your sh!t and knowing you're sh!t
10th Mar 2015 9:19am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
I would start with a hard battery reset to see if the instrument cluster ecu is "in distress" then check if infact the battery on her is any good? As the instrument cluster pixels on the 06> model nearly NEVER fail!
10th Mar 2015 12:08pm |
Vida Member Since: 12 Mar 2015 Location: Caracas Posts: 2 |
Good Nigth
12th Mar 2015 2:23am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
" hard reset "
12th Mar 2015 4:16am |
As above but for your information, even if you connect a diagnostic computer to your car with an ECU "in distress" there will be nothing you can do to reset it without a battery reset. So, that needs to be done first sir |
12th Mar 2015 9:19am |
Thanks to all who have replied....
12th Mar 2015 1:47pm |
Good afternoon.
13th Mar 2015 1:42pm |
