Home > Technical (L322) > L322 not warming up
GregoryT
Cyprus 2004 Range Rover Vogue Td6 Barolo Black
L322 not warming up..
Hi all
Have a cooling problem on a similar veh l322 TD6. It takes ages to warm up and moreover when going downhill the temp drops considerably
Any ideas where to look. Have change the Thermostat and Water pump as well as the Temp Sensor
Thanks/Greg
Post #312452 13th Feb 2015 12:52pm
GregoryT
Would be interested to see if anyone knows where the changeover valve is located.
Thaks
Post #313038 16th Feb 2015 12:11pm
Does sound like the thermostat, still....
Why did you change the thermostat in the first place, same problem?
Did you flush out the radiator while you had the chance?
What is the changeover valve you mention? .
Post #313069 16th Feb 2015 4:10pm
DavidP
Belgium 2006 Range Rover Vogue Td6 Bonatti Grey
I still have the same problem - came back/noticed it whilst driving over the mountain passes. I haven't changed anything yet!. Saying that if i set the hvac temp to 0 then the engine temp needle stays constant, may be its linked i don't know.
Post #313072 16th Feb 2015 4:26pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
Whilst fixing the over cooling problem on my TD6 a few years ago I found that their are a few thermostats on the TD6, either of which can cause over cooling if faulty, they are-
- Main engine thermostat
- EGR thermostat
- Oil cooler thermostat
(Could be more...)
In my instance the over cooling was caused by the oil cooler thermostat, this meant the car never got out of the blue on the temp gauge, but worse was the 19mpg as the car was on cold start all the time!
Post #313085 16th Feb 2015 5:14pm
sass
Finland 2014 Range Rover Vogue TDV6 Kaikoura Stone
It takes a long time for my TD6 to get out from the blue region now during the winter time. In the summer/autumn the needle would stay at 12 o'clock. When it gets below 10 degrees celcius the needle hardly reaches 10 o'clock. No visible difference when driving uphill/downhill or car remaining stationary. The thermostat on the engine was changed less than a year ago by the previous owner. The FBH has not worked during my ownership. The EGR valve is stuck closed.
Do you have suggestions? Thermostat on the oil cooler or the EGR?
Post #313206 17th Feb 2015 9:58am
@GregoryT
The changeover valve is item 24 on the diagram below.
Post #313217 17th Feb 2015 10:53am
GregoryT
Originally have changed the thermostat for the same problem. This is the second time I am changing the thermostat. The EGR valve is new. I suspect the Viscous fan but then again it should not drop to blue mark.
Post #313218 17th Feb 2015 10:57am
GregoryT
Thanks you for the diagram. I have been trying to locate this on the car but no success. It should be on the engine bulkhead but the pipe coming from the water pump goes directly into the FBH. I read on some articles that sometimes this valve is not fitter?? Andy idea on what the part number will be for this? The local RR dealer quoted Euro 350.00 for it.
Post #313219 17th Feb 2015 11:01am
Sorry I don't know the part numner.
It might be worth sending Dan at Duckworths your Vin number and asking him to check if your car is fitted with a changeover valve and if so the part number and price.
Have you considered removing the viscous fan and see if it has any effect on engine temperature?
Post #313220 17th Feb 2015 11:17am
GregoryT
Thanks
I will remove the Viscous fan and see if it makes a difference. Meantime, as i am new to this forum do you happen to have the email address of Dan? I still suspect the changeover valve(24) as if this remains open all the time we will have continues flow of the cold water back to the rad through the heater matrix.
Greg
Post #313226 17th Feb 2015 12:40pm
danroberts@duckworthlandrover.co.uk
Just mention you are a member on here. Thumbs Up
Post #313255 17th Feb 2015 2:38pm
GregoryT
Thanks a lot
Greg
Post #313265 17th Feb 2015 3:22pm
GregoryT
Hi all. I think we are nearly there. Change the EGR thermostat( I did not know that had one!!) and did part of the job. Then changed the fan viscous calpling and much better. The engine warms up quickly and maintains temp going down the hill. Will monitor further and keep you posted.
Rolling Eyes Rolling Eyes
Post #313533 18th Feb 2015 8:40pm
GregoryT
Tested it over the w/end coming down a mountain area driving fro 30 minutes. At the beginning it it maintained the temp but after a while guess what!! The temp gauge went back to blue area!!
Any more ideas as to where to look for??
Thanks
Greg
Post #314590 24th Feb 2015 10:42am
