![]() | Home > Technical (L322) > L322 not warming up |
GregoryT Member Since: 13 Feb 2015 Location: Limassol Posts: 11 ![]() ![]() ![]() |
Would be interested to see if anyone knows where the changeover valve is located.
Does sound like the thermostat, still....
DavidP Member Since: 20 Oct 2010 Location: BN Posts: 425 ![]() ![]() ![]() |
I still have the same problem - came back/noticed it whilst driving over the mountain passes. I haven't changed anything yet!. Saying that if i set the hvac temp to 0 then the engine temp needle stays constant, may be its linked i don't know. |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
Whilst fixing the over cooling problem on my TD6 a few years ago I found that their are a few thermostats on the TD6, either of which can cause over cooling if faulty, they are-
sass Member Since: 23 Apr 2014 Location: Helsinki Posts: 37 ![]() ![]() ![]() |
It takes a long time for my TD6 to get out from the blue region now during the winter time. In the summer/autumn the needle would stay at 12 o'clock. When it gets below 10 degrees celcius the needle hardly reaches 10 o'clock. No visible difference when driving uphill/downhill or car remaining stationary. The thermostat on the engine was changed less than a year ago by the previous owner. The FBH has not worked during my ownership. The EGR valve is stuck closed.
@GregoryT
Originally have changed the thermostat for the same problem. This is the second time I am changing the thermostat. The EGR valve is new. I suspect the Viscous fan but then again it should not drop to blue mark. |
Thanks you for the diagram. I have been trying to locate this on the car but no success. It should be on the engine bulkhead but the pipe coming from the water pump goes directly into the FBH. I read on some articles that sometimes this valve is not fitter?? Andy idea on what the part number will be for this? The local RR dealer quoted Euro 350.00 for it. |
Sorry I don't know the part numner.
Thanks
danroberts@duckworthlandrover.co.uk
Thanks a lot
Hi all. I think we are nearly there. Change the EGR thermostat( I did not know that had one!!) and did part of the job. Then changed the fan viscous calpling and much better. The engine warms up quickly and maintains temp going down the hill. Will monitor further and keep you posted.
Tested it over the w/end coming down a mountain area driving fro 30 minutes. At the beginning it it maintained the temp but after a while guess what!! The temp gauge went back to blue area!!
