Home > Maintenance & Mods (L322) > brembo calipers[front] conversion |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2032 |
I suppose that it's not just down to the pad area, but the force on the pad. (As well) ie if you had two tiny Pistons, you would need to push twice as hard as if you had four similar pistons, on same pad.
16th Feb 2015 11:51pm |
choplee Member Since: 11 Feb 2015 Location: Kent Posts: 31 |
where Brembo brakes a factory upgrade or standard on some models ????????? 57 - Silver TDV8 VSE loaded
17th Feb 2015 8:02am |
Brembo four pot callipers were introduced with the 2007 upgrade , removed for the 2010 upgrade and then six pot callipers came in with the 2011 upgrade . 2008 MY Supercharged
17th Feb 2015 8:09am |
ok cool cheers ...learning so much about my RR on this forum 57 - Silver TDV8 VSE loaded
17th Feb 2015 9:05am |
