Home > General > Could someone be trying to nick my rear lamps? |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
We do at least one car a month where the light/lights have been pinched! |
19th Mar 2013 11:16pm |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 |
This country gets worse its obscene that people's pride and joys are attacked like this. It would be a great modification if you could attach the screws to the battery so anyone tampering was shocked.
20th Mar 2013 7:24am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3972 |
Good this post was resurected, I would never have guessed it was so easy.
20th Mar 2013 10:30am |
Later models have them fitted, from around 07 on so if anyone wants to change theirs, main dealers will be able to supply the correct anti theft bolts |
20th Mar 2013 10:33am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
Take a look at this to see where parts are ending up:
20th Mar 2013 1:07pm |
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 456 |
these? http://www.a2a4.com/acatalog/A2A4_M6_TAM_T..._2184.html http://www.a2a4.com/acatalog/A2A4_M6_PIN_H..._2245.html |
20th Mar 2013 1:23pm |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 |
Damm this thread, anothering thing to be paranoid about....I will have to park fully backed up against walls from now on!
20th Mar 2013 1:57pm |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
20th Mar 2013 2:32pm |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 |
Sharia Law does have some good points |
20th Mar 2013 4:58pm |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 |
I think the Land Rover part number is FYP106392, retails at about 36p each plus VAT Tom
21st Mar 2013 10:50am |
Good thing I have the later screws on my TDV8 and the light grills from factory on the G4, they did not take the lights... they only took my ...winch! l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
19th Sep 2013 11:23am |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
Yes - later screws on the 2006 on - I had the same problem on a Disco a few years ago - you could unscrew those rear lights with a phillips screwdriver!
19th Sep 2013 11:39am |
Greg66 Member Since: 10 Nov 2010 Location: London Posts: 84 |
Got my pozi bolts through the post today so set about replacing the hex head bolts this evening. Except the hex heads come with a washer that I just can't remove from the bolt. It's as if the washer is fitted to the shank, and has. Whole too small to pass over the thread. God knows how it got onto the bolt in the first place.
23rd Sep 2013 8:05pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35271 |
it appears that the RRS chaps are having the same problem,
7th Jan 2014 11:47am |
