![]() | Home > General > Could someone be trying to nick my rear lamps? |
We do at least one car a month where the light/lights have been pinched! |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
This country gets worse its obscene that people's pride and joys are attacked like this. It would be a great modification if you could attach the screws to the battery so anyone tampering was shocked.
Good this post was resurected, I would never have guessed it was so easy.
Later models have them fitted, from around 07 on so if anyone wants to change theirs, main dealers will be able to supply the correct anti theft bolts |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2944 ![]() ![]() ![]() |
Take a look at this to see where parts are ending up:
SoggyBottoms Member Since: 05 May 2012 Location: Northants. Posts: 457 ![]() ![]() ![]() |
these? http://www.a2a4.com/acatalog/A2A4_M6_TAM_T..._2184.html http://www.a2a4.com/acatalog/A2A4_M6_PIN_H..._2245.html |
GraemeC Member Since: 01 Jul 2012 Location: Chester Posts: 836 ![]() ![]() ![]() |
Damm this thread, anothering thing to be paranoid about....I will have to park fully backed up against walls from now on!
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
Sharia Law does have some good points |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
I think the Land Rover part number is FYP106392, retails at about 36p each plus VAT Tom
Good thing I have the later screws on my TDV8 and the light grills from factory on the G4, they did not take the lights... they only took my ...winch! |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 ![]() ![]() ![]() |
Yes - later screws on the 2006 on - I had the same problem on a Disco a few years ago - you could unscrew those rear lights with a phillips screwdriver!
Greg66 Member Since: 10 Nov 2010 Location: London Posts: 84 ![]() ![]() |
Got my pozi bolts through the post today so set about replacing the hex head bolts this evening. Except the hex heads come with a washer that I just can't remove from the bolt. It's as if the washer is fitted to the shank, and has. Whole too small to pass over the thread. God knows how it got onto the bolt in the first place.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
it appears that the RRS chaps are having the same problem,
