Home > Technical (L322) > Can I trickle charge my battery in situ? |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 497 |
i have in the past yes. Cheers
28th Jan 2015 8:49pm |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 |
Yes...mines on the CTek right now . I give it a good charge every couple of weeks as I only do low miles.
28th Jan 2015 8:52pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7803 |
Same as Paul, I have the CTEK comfort connector on my battery and charge up every few weeks, as I only do about 10 mile a day and watch TV a bit at lunch times......
28th Jan 2015 9:20pm |
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 350 |
Hi mrblonde
28th Jan 2015 9:24pm |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 728 |
Cheers all
4th Feb 2015 10:11am |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3977 |
Connect to whichever is most convenient for you. |
4th Feb 2015 10:21am |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3747 |
or through the white trailer electric socket if you have one - saves opening the bonnet and plugs straight in if you wire a cable to the appropriate trailer plug to plug straight into the car socket - this is the quickest and safest way inho.
4th Feb 2015 1:18pm |
wealy Member Since: 29 Jul 2013 Location: Kings Bromley Posts: 1020 |
I have one and they work great - no need to lift the bonnet |
4th Feb 2015 11:00pm |
If this is any help to anyone.
15th Feb 2015 9:45am |
wilwak Member Since: 02 Oct 2015 Location: Hampshire Posts: 27 |
Ive just taken delivery of my new L405! Love it.
2nd Oct 2015 6:02pm |
CS Member Since: 14 Apr 2015 Location: Edinburgh Posts: 1385 |
I don't know about the 405, but when I had a battery failure on my 2004 322 4.4 (in a field by the Tweed on a Friday evening, sorted by Donald Lees Recovery of Galashiels who had the off road capacity to reach me) I needed to keep the battery alive over the weekend and had just a Triumph motorcycle branded trickle charger with a power socket adaptor to hand. I plugged that into the cigarette lighter socket and the charger showed it was working. I then just shut the (front) door on the charger cable and locked the car. There seemed no damage to cable or door seal (or the car's electrics) and the car started on the Monday and I got a new battery.
2nd Oct 2015 6:56pm |
Thanks CS. The pwer socket option is a good idea.
2nd Oct 2015 7:09pm |
Nothing in the manual about battery location....
3rd Oct 2015 11:47am |
Andy Member Since: 23 Feb 2009 Location: Shropshire Posts: 2938 |
I have an Optimate charger and I bought an extended lead to connect to the battery. I also use the trailer socket using another Optimate cable and a plug I bought from a caravan shop.
3rd Oct 2015 12:26pm |
