Home > Technical (L322) > Can I trickle charge my battery in situ?
Page 3 of 4 <1234>
Martin
Site Admin
Accessory plug? Confused
12V lighter socket type plug?
I can do, happy to be asked to make up any variation on the theme.
I have done Anderson plugs, an ignition switched version and a version for crocodile clip equipped charger, etc etc.
Post #350743 5th Oct 2015 1:49pm
wilwak
United Kingdom 2016 Range Rover Vogue SE TDV6 Corris Grey
Martin wrote:
Seems a good thread to plug my wares Wink
http://www.disco3.co.uk/shop/tow-electrics...c-p45.html
12S or 13 pin version and for various charger types.
Very nice product! Wish I had a towing connector now. That would make it so easy.
My connection under the bonnet is working ok but a but of a botch job really.
I've just ordered one of these to try it.
http://www.amazon.co.uk/CTEK-CTE-56263-Cig...160%2C160_
Post #350746 5th Oct 2015 1:53pm
Martin
Site Admin
You will need a permanently powered socket for that to work, or if the socket is ignition switched, find the relay which switches it on and bridge the terminals with a link wire to make it permanent.
It is, however, why I don't make a CTEK to cigar plug adapter Wink
Post #350750 5th Oct 2015 2:08pm
wilwak
I haven't tested them yet but I've been led to beleive that the socket in the boot is a permanent live.
I'll let you know when I test it!
Post #350752 5th Oct 2015 2:25pm
miggit
Yes Martin, a lighter plug Thumbs Up It would appear that there is a live one in all the ffrr's, the one in the boot, although if your car is of BMW origin then any socket will work, provided that the fuse is intact Shocked I just thought that it would be a cheaper option for those who don't tow with there Range Rovers Shocked ( I thought that was what they were made for, but it appears that I may have been mislead Laughing and contrary to popular belief, a towbar is an option and not standard equipment Shocked Shocked had to pick myself up after that one Rolling with laughter ) Yesterday I couldn't spell Engineer... Today I are one!
Post #350753 5th Oct 2015 2:35pm
PaulM
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
Can I ask what's the ctec fly lead? I currently have a ctec charging the RR but it's just connected under the bonnet to the battery. 2004 RR 4.4 V8 Autobiography
Post #351035 7th Oct 2015 2:30pm
Martin
Site Admin
The socket with ring terminals, fitted permanently to the battery.
I assume you are using the crocodile clips?
Post #351036 7th Oct 2015 2:37pm
PaulM
Yep, the crocodile clips but sometimes they pop off and the lead to ctec is not quite long enough. Also yesterday I noticed what looked like condensation in the small lights on the charger. 2004 RR 4.4 V8 Autobiography
Post #351040 7th Oct 2015 3:02pm
wilwak
I now have a perfect solution...
One these in to the socket in the boot.
And one of these to extend the lead
http://www.amazon.co.uk/CTEK-56-304-Comfor...P3W2KNN1ZM
The maintainer I'm using is one of these..
http://www.amazon.co.uk/CTEK-MXS-5-0-Tempe...words=CTeK
The extension cable just pops out the boot between the upper and lower parts and I connect it to the charger which is outside the vehicle.
Hope that helps.
Post #351045 7th Oct 2015 3:49pm
ajac8
I have a CTEK 5.0 with+/- cable permanently fixed to the battery terminals. This is rolled up and stored in the battery box when not in use. Simply pull out and connect to an extension lead of the Ctek - simples. regularly leave on charge all week as only use the fatty at weekends. Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #351047 7th Oct 2015 4:32pm
miggit
Shocked Shocked ajac8 does Pete know you got a thing going on with fatty? Only I fear that he might get the hump if he finds out your with his ffrr Shocked Shocked
wilwak, Have you spoken to Martin about that lead? I think he'll probably do you a better deal, and from what I understand he makes them, so you could get the exact length that you require Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #351112 7th Oct 2015 9:15pm
PaulM
I've just looked in my MXS 5.0 box and found one of those fly leads, so I'll use that. Only thing that bothers me is it doesn't have an inline fuse so if some scumbag decides to cut wires and join together then 😡 2004 RR 4.4 V8 Autobiography
Post #351201 8th Oct 2015 10:50am
wilwak
Mine is maintained inside a garage so I don't have that risk.
If you're worried about sabotage then maybe place the charger unit inside the boot and have the mains cable trailing out the boot? I've done that in the past.
The problem is that some of the latest ctek chargers have quite chunky mains cables. The older ones had thin ones.
Post #351297 8th Oct 2015 8:47pm
Surely it's easy enough to add an inline fuse ?
Post #351304 8th Oct 2015 9:32pm
PaulM
I'm not exactly worried as such, area is nice enough but I have a hard time trusting the human race 😁 2004 RR 4.4 V8 Autobiography
Post #351321 9th Oct 2015 2:23am
Page 3 of 4 <1234>
