Home > Technical (L322) > Can I trickle charge my battery in situ? |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
Accessory plug?
5th Oct 2015 1:49pm |
wilwak Member Since: 02 Oct 2015 Location: Hampshire Posts: 27 |
Very nice product! Wish I had a towing connector now. That would make it so easy. My connection under the bonnet is working ok but a but of a botch job really. I've just ordered one of these to try it. http://www.amazon.co.uk/CTEK-CTE-56263-Cig...160%2C160_ |
5th Oct 2015 1:53pm |
You will need a permanently powered socket for that to work, or if the socket is ignition switched, find the relay which switches it on and bridge the terminals with a link wire to make it permanent.
5th Oct 2015 2:08pm |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3657 |
Yes Martin, a lighter plug It would appear that there is a live one in all the ffrr's, the one in the boot, although if your car is of BMW origin then any socket will work, provided that the fuse is intact I just thought that it would be a cheaper option for those who don't tow with there Range Rovers ( I thought that was what they were made for, but it appears that I may have been mislead and contrary to popular belief, a towbar is an option and not standard equipment had to pick myself up after that one ) Yesterday I couldn't spell Engineer... Today I are one!
5th Oct 2015 2:35pm |
PaulM Member Since: 08 Mar 2015 Location: Warwickshire Posts: 190 |
Can I ask what's the ctec fly lead? I currently have a ctec charging the RR but it's just connected under the bonnet to the battery. 2004 RR 4.4 V8 Autobiography |
7th Oct 2015 2:30pm |
The socket with ring terminals, fitted permanently to the battery.
7th Oct 2015 2:37pm |
Yep, the crocodile clips but sometimes they pop off and the lead to ctec is not quite long enough. Also yesterday I noticed what looked like condensation in the small lights on the charger. 2004 RR 4.4 V8 Autobiography |
7th Oct 2015 3:02pm |
I now have a perfect solution...
7th Oct 2015 3:49pm |
ajac8 Member Since: 04 Oct 2011 Location: Shakespeares County Posts: 1656 |
I have a CTEK 5.0 with+/- cable permanently fixed to the battery terminals. This is rolled up and stored in the battery box when not in use. Simply pull out and connect to an extension lead of the Ctek - simples. regularly leave on charge all week as only use the fatty at weekends. 405 AB exec seats Baltic and Cirrus
7th Oct 2015 4:32pm |
ajac8 does Pete know you got a thing going on with fatty? Only I fear that he might get the hump if he finds out your with his ffrr
7th Oct 2015 9:15pm |
I've just looked in my MXS 5.0 box and found one of those fly leads, so I'll use that. Only thing that bothers me is it doesn't have an inline fuse so if some scumbag decides to cut wires and join together then 😡 2004 RR 4.4 V8 Autobiography |
8th Oct 2015 10:50am |
Mine is maintained inside a garage so I don't have that risk.
8th Oct 2015 8:47pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7950 |
Surely it's easy enough to add an inline fuse ? |
8th Oct 2015 9:32pm |
I'm not exactly worried as such, area is nice enough but I have a hard time trusting the human race 😁 2004 RR 4.4 V8 Autobiography |
9th Oct 2015 2:23am |
