Home > In Car Electronics (L322) > Td6 vogue sat nav not working
William97841
Hi people I've got 2003 td6 vogue with the per touch sat nav and before I brought it someone had to the battery changed and now the sat nav screen comes on but yet nothing else. I can't access the radio the tv comes on and searches but finds nothing and the word 'code' is blacked out and I can't access it? And secondly the sat nav drive has eject red light but no power light??.
Any ideas??
Post #307919 25th Jan 2015 6:40pm
SteveMFr
Site Sponsor
Hi William,
If you have an 03, you def do not have a touch-screen nav unless it is one of the Chinese aftermarket units.
If yours is original (foundry grey face - not black): you are pressing the volume (left) knob to try to turn the radio on? If you are seeing 'Code', are you able to enter anything (turn the right hand knob to change characters). If you can, enter 0000.
Can you eject a CD/DVD when you press eh eject button on the Satnav computer?
If none of this works, take a pic and post.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #308486 27th Jan 2015 1:38pm
William97841
Yep that's the one your talking about is my one the grey one. Yep I've tried what you said and it still does not work won't let me out a code in. So I'm kinda stuck. I think the sat nav drive is faulty because that also doesn't do anything thanks for your reply
Post #308872 28th Jan 2015 10:34pm
sometimes if you disconnect the battery the ecu's reboot and all is well, worth a try...details how to are in the wiki.. ... - .- -.
Post #308914 29th Jan 2015 7:47am
William97841
Hi yep I've tried that as well,actually had the battery out and touched to cables together then put it back still the same oddly though on my screen where it should say road navigation nothing is there very weird
Post #309063 29th Jan 2015 4:53pm
is there any water in the rear cubby hole.. ... - .- -.
Post #309065 29th Jan 2015 4:59pm
Two things, are all the boxes in place in the boot and plugged in and secondly have you looked at the condition of any of the connectors on the plugs and sockets. I'm afraid water damage to the various units and connectors is a serious problem in these cars.
Have you seen any of the units working?
Post #309066 29th Jan 2015 5:01pm
William97841
Nope no water in chubby all dry. Not saying there hasn't been at some point but nothing from where I can see.
All connections are in place I haven't seen them working so I know it could be anything. But I was just trying to eliminate one at a time if I could. Any advice on how to check them??
Post #312515 13th Feb 2015 5:37pm
The first thing I would do is undo the largest of the three plugs on the top of the DSP unit, the box nearest the back of the car, and look for signs of corrosion in the plug and the pins in the socket.
If you find any also remove the other two plugs and similarly look for corrosion.
Post #312520 13th Feb 2015 6:17pm
William97841
Right here's a pic of what my radio screen looks like. I have checked for water and the moisture on the plugs no sign of anything. No water stains either. Sorry had 2 weeks away
Post #313420 18th Feb 2015 10:37am
William97841
I dunno if the pic uploaded
Post #313422 18th Feb 2015 10:44am
William97841
Sorry pic won't upload for some reason....bloody hell!! U gotta click on my gallery to see it
Post #313427 18th Feb 2015 10:52am
Post #313430 18th Feb 2015 11:06am
William97841
Sweet as cheers Stan Thumbs Up
Post #313436 18th Feb 2015 11:40am
William97841
Any help??
Post #313772 19th Feb 2015 8:05pm
