![]() | Home > In Car Electronics (L322) > Td6 vogue sat nav not working |
mbmarkyb Member Since: 18 Jan 2015 Location: basingstoke Posts: 22 ![]() ![]() ![]() |
I had the same issue . I had blue pins on most of the connectors . power pin broken on the dsp and a furry pcb inside the sat nav. I cleaned all the connections and board and the sat nav came back but would freeze now and again. I have now dumped the dsp and chopped the plugs and wired it in direct to a small amp for now .
William97841 Member Since: 18 Jan 2015 Location: Essex Posts: 141 ![]() ![]() ![]() |
So I pulled off all the plugs and pushed them all back together still no joy. All fuses are fine ive tried to check about the phone cables had a 2 cable like a purple pink connector lose. Only bit of corrosion I got was with the big black plug with the 10amp fuse in it (box infront of the tv box) was a bit.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8558 ![]() ![]() ![]() |
Box you are talking about with the corrosion is the radio...
Yes that's the ne the radio one.
If people need to know I've fixed the radio now have audio and everything working apart from sat nav drive broken and that was power draining the car bloody thing lol.
