![]() | Home > Technical (L322) > Early EAS, Has anyone cracked the slow to lift symptoms? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
My air suspension takes a long time to lift the car between heights, 25-30 seconds, this is the norm |
New Compressor!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35651 ![]() ![]() |
your compressor is over 10 years old so i imagine its worn a bit... i would repair or replace to get it working quicker, thats if more speed is needed.. ... - .- -.
My compressor is less than 2 months old and was brand new not a referb, so I don't think that is to blame. I do remember the under lying theme of all the threads that I have read on early L322 EAS, is it is slow, very slow, I'm just trying to down grade it to P38 speed |
i would have thought a new compressor would have pumped it up quicker..
Oh don't get me wrong, the new compressor will lift the car from entry height to offroad in just under a minute. Which from what I gather is the norm for the early cars, but I'm also lead to believe that the later cars with the Hitachi pump will do it in around 30 seconds |
from access to standard is 40mm, from standard to off road is 60mm, only 10mm but maybe that's why it takes longer.. ... - .- -.
Hmmmmm don't like your maths much Stan, think you mean 20 mm, but I get the idea, makes sense to me, but can I improve on it? Like Clarksons answer to every thing MORE POWER! or should it be more air |
At last someone who's talking MORE AIR |
See |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8546 ![]() ![]() ![]() |
I've sourced a second compressor and plan on having a twin pump set up, shouldn't be too hard to plumb...
I was going to piggy back the electrical connections, using just one temp sensor and "T" in the air lines.
