Home > General > thoughts on remap |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 |
If it is a Td6 the remap does make a huge difference.
31st Aug 2010 5:34pm |
m10rng Member Since: 18 Aug 2010 Location: london Posts: 64 |
"If it is a Td6 the remap does make a huge difference"-- is this because you have done this??
1st Sep 2010 2:13pm |
Yes, I had mine chipped as soon as I got it, and have done 90000 since.
1st Sep 2010 2:53pm |
he said to me
1st Sep 2010 2:55pm |
1st Sep 2010 4:07pm |
thanx |
1st Sep 2010 4:15pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35460 |
does the mpg go up, and if so , by how much.. ... - .- -.
1st Sep 2010 5:23pm |
The MPG gets a little better but you have to teach your gearbox to shift up early to use the extra torque and to do that you must accelerate every where on as light a throttle as possible. It also seems to do another trick where to overtake hard you floor the throttle but lift off straight away and then plant the throttle and the car will now accelerate as hard as it can in a higher gear and I find this helps.
1st Sep 2010 6:26pm |
cheers axle, what about the statement that a remap might cause excessive wear on the gearbax etc.. ... - .- -.
1st Sep 2010 8:12pm |
Nappler Member Since: 09 Jun 2010 Location: Surrey Posts: 158 |
Is a remap on a TD6 a pretty sure way to wreck the gearbox?. |
2nd Sep 2010 10:48am |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 |
Paul, is this the same car that eats gearboxes and diffs, which you mentioned in anoter post? |
2nd Sep 2010 10:55am |
As I said chipping can cause excessive wear.
2nd Sep 2010 5:49pm |
got the car bak, got a tip from garage man to drive it hard for a full tank worth so engine can recognise the driving style and adjust.
2nd Sep 2010 8:00pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
what about the petrol remaps, any one had one... V8 facelift Range Rover Autobiography 22" wheels.
2nd Sep 2010 8:23pm |
