Home > General > thoughts on remap
m10rng
United Kingdom 2004 Range Rover HSE Td6 Java Black
thoughts on remap
£250 for a ECU remap
not through a box being installed but they will do it through firmware
good/bad?
Post #26873 31st Aug 2010 3:44pm
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
If it is a Td6 the remap does make a huge difference.
£250.00 does sound cheap, most reputable firms charge a lot more.
A remap can cause excessive wear on the drive line and the gearbox!
who is offering the £250 remap?
Post #26890 31st Aug 2010 5:34pm
m10rng
"If it is a Td6 the remap does make a huge difference"-- is this because you have done this??
friend of a freind. he usually charges round the £400 -£500
Post #26978 1st Sep 2010 2:13pm
Pauld
Yes, I had mine chipped as soon as I got it, and have done 90000 since.
It's speed does surprise people!
Post #26982 1st Sep 2010 2:53pm
m10rng
he said to me
around 40 -50 more hp and around 400 torque.
does this sound right?
Post #26983 1st Sep 2010 2:55pm
Pauld
Post #26987 1st Sep 2010 4:07pm
m10rng
thanx
Post #26989 1st Sep 2010 4:15pm
does the mpg go up, and if so , by how much.. ... - .- -.
Post #26996 1st Sep 2010 5:23pm
The MPG gets a little better but you have to teach your gearbox to shift up early to use the extra torque and to do that you must accelerate every where on as light a throttle as possible. It also seems to do another trick where to overtake hard you floor the throttle but lift off straight away and then plant the throttle and the car will now accelerate as hard as it can in a higher gear and I find this helps.
I had my TD6 re-mapped two years ago and it transforms the engine (still a bit vocal though) 400 nM of torque sounds about right but an extra 50 hp is a bit more than most tuners say you can safely get , just over 200 hp seams the norm.
With the caveat that these figures are what I have seen written but I haven't personally put mine on a dyno. 2008 MY Supercharged
Post #27007 1st Sep 2010 6:26pm
cheers axle, what about the statement that a remap might cause excessive wear on the gearbax etc.. ... - .- -.
Post #27032 1st Sep 2010 8:12pm
Nappler
2003 Range Rover Vogue 4.4 V8 Java Black
Is a remap on a TD6 a pretty sure way to wreck the gearbox?.
Post #27067 2nd Sep 2010 10:48am
Fox
Paul, is this the same car that eats gearboxes and diffs, which you mentioned in anoter post? Shocked
Post #27069 2nd Sep 2010 10:55am
Pauld
As I said chipping can cause excessive wear.
Mine is chipped more than most, and is driven very hard.
The chap who did mine had a Td6 with over 250 Bhp, races a comp safari bowler and scares the life out of me when on the car. His has done 120000+ miles on the original gearbox.
Chipping can cause gearboxes to go, it does depend on how you put the power down.
At least one of my replacements was faulty
Post #27109 2nd Sep 2010 5:49pm
m10rng
got the car bak, got a tip from garage man to drive it hard for a full tank worth so engine can recognise the driving style and adjust.
after 15 minute drive started to feel the difference.
all in all Thumbs Up
but will paying another visit in 6 months for a further increase Wink
Post #27135 2nd Sep 2010 8:00pm
daveo
what about the petrol remaps, Question any one had one... V8 facelift Range Rover Autobiography 22" wheels.
Post #27139 2nd Sep 2010 8:23pm
