Home > Wheels & Tyres > Tyre wear
Steverr
United Kingdom 2003 Range Rover Vogue Td6 Zermatt Silver
Tyre wear
Hello I've got a little excessive tyre wear on the outside of the rear left Crying or Very sad any ideas, !!! Wheel, ? Bushes. Had the 4 wheel tracking done around 6 months ago. Tyres were used and already on the wheels when I bought them !!
Post #299508 17th Dec 2014 5:06pm
Take it back to where you had the tracking done , because thats not good . 2008 MY Supercharged
Post #299580 17th Dec 2014 10:37pm
johnboyairey
Have you had the rear bushes looked at for wear? They could be very worn and out of alignment when driving, but in true when resting on tracking machine. There was a posting recently on a Diy repair to show the bushes. They can be a right wot sit to remove.
Post #299583 17th Dec 2014 10:48pm
They look like 20" Toyo Proxes? Never heard a good word said about them in 20" I'm afraid Steve... (22" Toyo's are excellent before i get shouted at)
Agree with above, rear bushes are usually the culprit... Still, your tyre will need changing & i personally would NOT buy the same to replace them sir Thumbs Up
Post #299585 17th Dec 2014 11:01pm
Upper and lower rear hub bushes and perhaps control arm too, then 4 wheel alignment again. Sorted it for me after I had gone through two tyres, I got down to the belts first time round before spotting it! oh, do both sides for good measure, then you know where you are. Howto on the wiki if you like the spanners. .
Post #299586 17th Dec 2014 11:04pm
CG-SC
2006 Range Rover Autobiography Supercharged Zambezi Silver
100% rear bushes.........don't ask me how i know Rolling Eyes Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather.....
Post #299654 18th Dec 2014 12:09pm
Steverr
Cheers guys. In tomorrow new tyre then check the bits as recommended Thumbs Up
Just a quick thought.... Would that cause wheel wobble type effect ?
Post #299699 18th Dec 2014 5:47pm
Depends how Censored the bushes are Steve...
Post #299728 18th Dec 2014 8:02pm
Steverr
Well... new tyre fitted, only to find out one of the front ones is bigger than the rest Big Cry Big Cry may explain the wobble feeling then !!!!
Post #300013 20th Dec 2014 11:00am
Don't wait too long before you sort out the bushes, otherwise you'll be in for another new tyre! .
Post #300026 20th Dec 2014 11:58am
johnboyairey
or even TWO tyres! and a remaining wobble.
if you go to an MOT garage, they will easily be able to raise a wheel an inch off ground, place a crowbar under rear wheel treads, and lever/rock the wheel up an down, feeling the bushes, and probably show you them, clunking all over the place. at rest, the tyre is straight, as you drive, it drags sideways, wearing the edge etc. slowing you down too!
joe90 did a good WIKI showing their methods of removal etc. car will be like magic carpet after. -remember to align after all bushes checked/renewed etc.
Post #300053 20th Dec 2014 2:09pm
