Home > General > No Drive |
liverpoolphil Member Since: 28 Jan 2010 Location: Lancashire Posts: 111 |
great post elpeede thanks |
28th Aug 2010 4:26pm |
Pauld Member Since: 15 Mar 2010 Location: Sheffield Posts: 199 |
that looks expensive |
29th Aug 2010 11:27am |
a broken switch on an FFRR is expensive, question is......is this the diff gone? (covered by recall ) Or something else not covered |
29th Aug 2010 11:29am |
Not covered, this would result in loss of drive, even with a good diff |
29th Aug 2010 11:31am |
Discocuzzy Member Since: 02 Aug 2010 Location: Surrey Posts: 94 |
Looks like drive shaft from the diff to a knackered drive hub, if so wont be covered |
29th Aug 2010 11:43am |
but at least I know what it is now - thanks to your help - off to the LR specialist first thing tuesday |
29th Aug 2010 11:59am |
out of interest, would you consider the drive shaft replacement as a difficult (technical) job?
30th Aug 2010 8:33am |
Phil i would get the motor checked first to see if its only the half shafts (these are the ones that come out of the diff to the drive flanges on the wheels)
30th Aug 2010 8:37am |
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2042 |
Phil
30th Aug 2010 9:22am |
its acutally the whole left wheel unit, so I assuming if anything else in that area has gone, a total replacement may be the answer
30th Aug 2010 9:43am |
the fleabay guy let me down
31st Aug 2010 4:08pm |
Try Famous Four for parts, may be a better price..
31st Aug 2010 5:31pm |
cheers Paul - famous four is slightly better at 260+VAT
31st Aug 2010 6:56pm |
CWs 4x4
31st Aug 2010 7:04pm |
