Home > General > No Drive
Page 2 of 3 <123>
liverpoolphil
United Kingdom 2003 Range Rover HSE Td6 Tonga Green
great post elpeede thanks Thumbs Up
Post #26666 28th Aug 2010 4:26pm
liverpoolphil
been for a good look over the car this morning, found this
That is coming from the front diff? to the leff hand wheel
Post #26692 29th Aug 2010 11:12am
Pauld
United Kingdom 2004 Range Rover Vogue Td6 Zermatt Silver
that looks expensive Big Cry
Post #26695 29th Aug 2010 11:27am
liverpoolphil
a broken switch on an FFRR is expensive, question is......is this the diff gone? (covered by recall Wink ) Or something else not covered Big Cry Big Cry Big Cry Big Cry
Post #26697 29th Aug 2010 11:29am
Pauld
Not covered, this would result in loss of drive, even with a good diff
Post #26698 29th Aug 2010 11:31am
Discocuzzy
Looks like drive shaft from the diff to a knackered drive hub, if so wont be covered Big Cry
Post #26701 29th Aug 2010 11:43am
liverpoolphil
Big Cry Big Cry Big Cry Big Cry Big Cry but at least I know what it is now - thanks to your help - off to the LR specialist first thing tuesday
Post #26704 29th Aug 2010 11:59am
liverpoolphil
out of interest, would you consider the drive shaft replacement as a difficult (technical) job?
Found a replacement on flea bay, seller is local and said he will fit it as well. His feedback is very positive, although he is more like a breaker than LR specialist.
Post #26761 30th Aug 2010 8:33am
Discocuzzy
Phil i would get the motor checked first to see if its only the half shafts (these are the ones that come out of the diff to the drive flanges on the wheels)
It looks like you may also need a new CV joint and or drive flange but dont take my word, get it checked first before parting with any dosh on the bay Thumbs Up
Post #26763 30th Aug 2010 8:37am
nbunney
Phil
Easy job, Undo Hub nut, drop bottom arm, take shaft out, put new 1 in, refit bottom arm / hub nut. well that was all I had to do on my rally Nova.
But it may have damaged the diff. Depends how cheap the 1 on fleagay is.
Post #26765 30th Aug 2010 9:22am
liverpoolphil
its acutally the whole left wheel unit, so I assuming if anything else in that area has gone, a total replacement may be the answer
Other influence is that there's a good chance he can do it today, due to work etc (without a car) it will be mid week at the latest before I can get it to him, thats hoping he can see to it straight away which is unlikely Neutral .
Post #26766 30th Aug 2010 9:43am
liverpoolphil
the fleabay guy let me down Big Cry
Got a price from LR today £350 Big Cry Big Cry Big Cry Big Cry
Found another from the bay but its off a 4.4V8 (not Td6) would these be the same part?
Post #26879 31st Aug 2010 4:08pm
Pauld
Try Famous Four for parts, may be a better price..
Not sure about the 4.4 vs Td6 difference
Post #26889 31st Aug 2010 5:31pm
liverpoolphil
cheers Paul - famous four is slightly better at 260+VAT
Speaking with the specialist, we discussed new vrs 2nd hand and, given the price different + the fact that its not a particularly common issue, 2nd hand is probably the best way forward
Just need to find one.....and fast Rolling Eyes
Post #26898 31st Aug 2010 6:56pm
Pauld
CWs 4x4
There is another but the name escapes me at the moment
Post #26899 31st Aug 2010 7:04pm
Page 2 of 3 <123>
