Home > Off Topic > heating a room
Welshdragon
heating a room
Well the extension build on the house has started, in a conversation with the Mrs, she has asked about underfloor heating in the kitchen and dinning room as we have never had this in any of our houses I was as a loss to answer if its a good idea or not Confused
Have any of you guys rate underfloor heating or is it not worth the agro in fitting, and cost of it running it cheaper than normal radiators? Our kitchen will be 5.6 x 4.5 metres, dinning room similar size, not small but not too big either. If it dont work.......burn it!
Post #297089 4th Dec 2014 10:46pm
A1GSS
It's fab. I'd always go for it now if I can. Thumbs Up Graham
____
Gone: 10MY L320 RR Sport HSE, Ipanema Sand
Gone: 20MY Jaguar iPace HSE, Silicon Silver
Gone: 17MY RR Evoque SE Tech, Loire Blue
Gone: 08MY Discovery 3 XS, Stornoway Grey
Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey
Post #297091 4th Dec 2014 10:48pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
good if you have concrete floors, doesn't work well on wooden floors. Not good if you have carpet on top of it either, but makes a tile floor toasty 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #297096 4th Dec 2014 11:08pm
I've done my whole house with it.
It's difficult to answer your questions without knowing more about the property. I have a heat pump, which is very efficient to heat water to about 40°C, which is inadaquate for radiators as they have a low surface area. So I chucked the radiators and installed underfloor heating. This was during a major refurbish, so was definitely worthwhile.
If you install it in part of your house, and it's a water system, you need a lower temperature otherwise it will be cold where there are radiators and/or hot where there is underfloor heating.
It also limits what you can put on the floor. I have wood flooring - which isn't great for underfloor heating, but it must be engineered wood. Solid wood will warp.
There are lots of issues to weigh up and it depends very much on your house. If you do it though it is lovely - much better than radiators. :thumbsup:
Post #297097 4th Dec 2014 11:14pm
We have it in our bathroom and love it. Thumbs Up Si. <This is my name.
Post #297130 5th Dec 2014 8:23am
Robert
France 2007 Range Rover Vogue 4.4 V8 Zambezi Silver
Dependig on your heater, floor insulation and topfloor it is very comfy. You do need a stone or tile floor though. If you're thinking of a wooden topfloor it's no use.
Post #297134 5th Dec 2014 8:33am
I have a wooden floor Robert, and many others do. It does work, although as wood is quite a good insulator, it doesn't work any where near as well as stone. You also have to choose your wood carefully. It is nice to walk barefoot on a heated stone floor though - as my bathroom is, and as I will finish my basement.
Post #297144 5th Dec 2014 8:59am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
I put it in the conservatory on a well insulated base. ( polystyrene and turkey tinfoil to reflect heat)
I heat mine using the return leg of the central heating and its always comfy in there without any additional heat.
As the chaps have said floor finish affect the results I have laminate. It can be slow to warm from cold as you are creating a thermal mass but when up and running much better than radiators and a lot easier to install during the build.
The electric version is good but expensive to run Mine was a blue one! Smile
Post #297147 5th Dec 2014 9:13am
put it this way, i build quite a few houses and have never used it and with sap compliance on new builds UF heating makes meeting the TER/DER very difficult. Which in layman's terms means though on the face of it it would seem quite an efficient way to heat the space, the actual energy use calks for it shows it to be inefficient, at least in the houses we build. I'm not sure why this is, but iirc the calks are moving away from thermal mass being a good thing, and a lot of energy goes into heating the screed (high thermal mass) that the pipes are bedded in before you get a useable amount of heat out.
it is however nice and toasty on the feet. There is nothing that can't be fixed with a hammer😜😜
Post #297226 5th Dec 2014 6:07pm
If this was installed how deep would the floor need to be dug out to keep a level surface running though a house? I fancy it in the kitchen but think the ballache of digging out the old floor to lay insulation and new screed would make standard rads the way to go. I know electric is quick and easy but need a weekly lotto win to run the stuff. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #297240 5th Dec 2014 7:59pm
i reckon you should need to go down, 50mm for the screed, 75mm for the insulation (minimum, wouldn't comply with new regs) and 100mm for a new ground bearing slab more if you need new hardcore sub base. so 9inches min below finished floor if the sub base is ok. There is nothing that can't be fixed with a hammer😜😜
Post #297245 5th Dec 2014 9:12pm
Sandyt
I have used it in a couple of houses the current one mix of air heat pump and ground heat pump driven by solar panel assist so not too expensive to run
Post #297248 5th Dec 2014 9:43pm
Welshdragon
Cheers guys Bow down , looks like that's the way forward to heating the kitchen and dinning room Thumbs Up
No wood floors in kitchen or dinning room so happy days Very Happy If it dont work.......burn it!
Post #297252 5th Dec 2014 9:55pm
Tell me about it.
Post #297328 6th Dec 2014 11:43am
You building a dungeon David? Laughing
Post #297329 6th Dec 2014 11:45am
