Home > Technical (L322) > Brake Disc Refinishing in Manchester
Does anyone know of any companies that do this at all or is it best to just try a normal engineers shop as i dont want to check an almost brand new disc away for the sake of a few minutes being ground true again Sad
Sure it was done on Wheeler Dealers(i know, i know!) but thought maybe it does exist in the real world. IIRC they did it on a boxster that was out of true.. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #296355 1st Dec 2014 5:49pm
Sandyt
To be honest the tolerance on them thickness wise is from memory not a lot 2/3mm each side so you may well grind past it I will try and find the thickness tolerance
Post #296358 1st Dec 2014 5:53pm
paulmoran2
England 2013 Range Rover Vogue SDV8 Mariana Black
Will...Here??>>
http://www.skimmydiscs.co.uk/find-your-nearest-service-centre/ GONE 2010 Facelifted 3.6 TDV8 - Stornoway Grey + 22" Overfinch Olympus
HAVE 1999 Discovery 2 GS 4.0 V8 - Silver - Off Road Toy
GONE 2013 L405 4.4 SDV8 Vogue. Black with Silver roofline and 22" s
HAVE 2015 Jaguar XF.
Post #296379 1st Dec 2014 6:14pm
The thing is while it may only allow 2-3mm wear cutting them true should take a lot less than that as iirc even .1mm uneven wear causes the symptoms I'm feeling Sad
Cheers Paul I've found one only a few miles away so will hit them up tomorrow Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #296388 1st Dec 2014 6:37pm
Philip
Discs rarely warp, if they're newish discs it's most likely uneven pad deposits which you might be able to scrub off.
Post #296393 1st Dec 2014 6:47pm
Deffo a bit of warp as a slide pin became solid. Cleaned it all out and freer and a ho's drawers but the small vibration is still there despite my braking purge to clean out the pad deposits so Deffo needs a light skim it's very slight but I caught it early I hope. If not I'll just buy a new disc as they aren't that old. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #296397 1st Dec 2014 6:55pm
You could do a dial test but like the others I doubt the disc is actually warped it almost never happens unless it wan miss manufactured . Tolerance on the discs is 1. 6 mm so not allot to play with. 2008 MY Supercharged
Post #296486 2nd Dec 2014 12:30am
Symptoms are,
Very very light vibration after a minute or two at sustained speed over 50 and then when below that speed.
Applying brakes results in more severe vibration from the front passenger wheel.
I checked the caliper and found a slightly seized slide pin so cleaned it out and well greased it up as well as other pin and now sweet as a nut.
Cleaned he pads a little with a light sand paper swiping.
I'll see how much this is to do, a new disc is £40 so if it's more than £20 I'll pot the idea and just buy a new disc.
The discs and pads all round aren't that old and haven't covered many miles so hardly worn but drove fine for 3 tankfuls of diesel before hand so warping is the only logical conclusion.
A run out test will confirm it but they reckon it takes 9mins per disc so worth a shot if they only take 30mins all in Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #296488 2nd Dec 2014 12:49am
As an update to this i bought a new disc genuine for £30 delivered:)
Fitted it after cleaning up the caliper sliders and job was a good en.
Then i got less subtle symptoms again.
The water test showed it was the drivers rear caliper sticking Sad
http://www.fullfatrr.com/forum/topic14982.html?highlight=rear
The post above is for the otherside so i guess at least both now are done and should last a good few years! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #299575 17th Dec 2014 10:21pm
Sandyt
Good luck with the change and hope it solves the prob Thumbs Up
Post #299600 18th Dec 2014 5:18am
Can i just mention to forum members... Please consider doing BOTH rear callipers together! I seem to read coutless times on here about members finding "the other side is now sticking" usually within months of having the first changed...
This runs the risk of ruining another set of disks/pads/brake fluid/wheel bearing's etc etc etc and imho is false economy & bad practice if carried out by garages...
Post #299606 18th Dec 2014 6:00am
Well after a test run last night it appears to be sorted fingers crossed.
Totally understand that Craig Smile when I did the first one ninjas check the other side and it was moving well enough but I have got two years and a few more miles out of it Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #299616 18th Dec 2014 8:50am
I did start that with "can i mention to forum members" Will... Not directed at you my friend... After all your old enough & pretty enough to make up your own mind sir Whistle Whistle Whistle
Who could possibly tell you the pitfalls of trial & error on a FFRR sir Whistle Whistle Whistle Laughing
Just wanted in-experienced members to understand how much they can A, ruin on there car & B, how much money they can be taken advantage for by not changing both...
Post #299631 18th Dec 2014 10:12am
That's cool Craig I knew it wasn't directed at me Smile
And shucks you've made me all red saying I'm purdy 😄😄😄 FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #299635 18th Dec 2014 10:40am
Neutral Neutral Neutral
Post #299636 18th Dec 2014 10:42am
