![]() | Home > Technical (L322) > Brake Disc Refinishing in Manchester |
Does anyone know of any companies that do this at all or is it best to just try a normal engineers shop as i dont want to check an almost brand new disc away for the sake of a few minutes being ground true again |
Sandyt Member Since: 07 Nov 2013 Location: Wraysbury Windsor Posts: 2272 ![]() ![]() ![]() |
To be honest the tolerance on them thickness wise is from memory not a lot 2/3mm each side so you may well grind past it I will try and find the thickness tolerance |
paulmoran2 Member Since: 27 Nov 2013 Location: Leeds Posts: 1422 ![]() ![]() ![]() |
Will...Here??>>
The thing is while it may only allow 2-3mm wear cutting them true should take a lot less than that as iirc even .1mm uneven wear causes the symptoms I'm feeling |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2593 ![]() ![]() |
Discs rarely warp, if they're newish discs it's most likely uneven pad deposits which you might be able to scrub off. |
Deffo a bit of warp as a slide pin became solid. Cleaned it all out and freer and a ho's drawers but the small vibration is still there despite my braking purge to clean out the pad deposits so Deffo needs a light skim it's very slight but I caught it early I hope. If not I'll just buy a new disc as they aren't that old. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
You could do a dial test but like the others I doubt the disc is actually warped it almost never happens unless it wan miss manufactured . Tolerance on the discs is 1. 6 mm so not allot to play with. 2008 MY Supercharged
Symptoms are,
As an update to this i bought a new disc genuine for £30 delivered:)
Good luck with the change and hope it solves the prob |
Well after a test run last night it appears to be sorted fingers crossed.
I did start that with "can i mention to forum members" Will... Not directed at you my friend... After all your old enough & pretty enough to make up your own mind sir |
That's cool Craig I knew it wasn't directed at me |
